Hi
As discussed here: https://communities.bentley.com/products/programming/microstation_programming/f/microstation-programming---forum/186087/extract-item-types-attached-to-models-with-vba/ there seems to be some problem with reading the item types values with VBA.
A workaround that could work for me is to use the reports-tool. But in order to do that, I would have to export the report as a .csv-file. Is there a way to do this tough VBA or key-ins?
Robert
Robert Högberg said: I would have to export the report as a .csv-file
Please vote for this Idea!
Done!
