I have a masterplan with say 500 parcels, each has to be labeled with its area, each parcel is made of shape or complex shape, each labels is placed inside of the shape / complex shape.
I want to use text fields to set the parcel area value. the only way I can think of is to double-click on each text field, right click "reassign field", click the shape and confirm. which is quite boring and time consuming thing, not to mention there is high probability for error.
is there a way to reassign all the text fields automatically? I understand there is probably no such tool in MS directly, but how to do it via VBA or something else? either in V8i or CE
thanks
Peter Tegza said:I have a masterplan with say 500 parcels, each has to be labeled with its area, each parcel is made of shape or complex shape
Take a look at AreaAnnotator or MasterPlanner.
Peter Tegza said:either in V8i or CE
Those tools are for MicroStation CONNECT Edition. There's no API for text fields in MicroStation V8i.
thanks Jon, gonna try it. pity it does not work in V8i, there are still some tools I need to work with available only for V8i. so I jump back and forth for now
/pt
LA Solutions did make an Area Annotator and Tagger for v8i ( used to be free) from memory it used tags which made it also great for doing reports and imports label ids as well as areas and send to text or csv and manipulate as tabulated data ie totals dates etc...but doesn't auto update, you have to rerun reports to get updates...
If your not fussed about it NOT being fields and Not Tags and just text, I have an old BAS for V8i that hijacks a free Select Bentley mdl called ATool.ma and uses a fence or selection it then labels the selected measured areas ( by the mdl)places the values at the centroid of all closed shapes in one go, but draw back is if you modify and shapes then you need to rerun it, I used to use this a lot for labelling proposed new subdivisions with existing title lots, the trick was to put the existing on a different level and turn them off then run the basic macro, but no ability to create reports and define from types ie commercial, residential , proposed etc only by level names that polygons are on or off...
Lorys
Lorys said:LA Solutions did make an AreaAnnotator and ShapeTagger for v8i
Thanks for the citation, Lorys!
AreaAnnotator and ShapeTagger remain freeware for MicroStation V8i.
AreaAnnotator CONNECT Edition learns from its predecessor. It includes additional functionality requested by users over the years. It permits bulk annotation of multiple shapes (making ShapeTagger unnecessary for CONNECT). It makes use of CONNECT Reports and Picklists. AreaAnnotator CONNECT Edition is a licensed product.
