I have developed a macro to report the override and display settings on levels in an active drawing and it's attachments(including one level of subreferences). Outside of microstation (i.e. in excel) I check the settings and highlight any required changes. A second macro is then used to implement any necessary changes back into the drawing. This part is working successfully and the changes are made, and amended setttings are evident in the active view and in the level manager etc. However the changes are not saved when the drawing is closed, despite liberal use of 'levels.rewrite' and 'RewriteLevels' in the updating macro. All the required changes can be implemented manually, and persist when the drawing is saved. Although I have found similar problems discussed, for what would seem to be a common task, and tried various suggestions, the problem persists. I would welcome any suggestions as what I might have missed. Thanks.
Hi Jonathan,
The VBA Help topic: "RewriteLevels" (and this post) suggest calling RewriteLevels when making changes to the collection, then finalize by calling levels.rewrite. Please verify if the order is correct.
If still having an issue consider providing a simplified Test Case consisting of your (exact) code and sample design file data so others can attempt to reproduce your exact issue and help resolve.
HTH,Bob
JONATHAN BAYLISS said:All the required changes can be implemented manually, and persist when the drawing is saved
Do you invoke the programmatic equivalent of Save Settings?
Thanks both for the quick response.
My understanding was that RewriteLevels was effective for levels in the main drawing, but levels.rewite was needed when working with attachments - but I tried both in different combinations anyway.
I will prepare a test case but may take a little while, the code is embedded with excel vba, so not easily understood out of context.
I do not specificically save settings from the macro, but I did try saving settings manually, after editing with the macro but before closing, but made no difference.
Jonathan
This is interesting, I am having the same problem with changes being made by VBA but these not being saved.Microstation 10.15.02.11If i useoLevel.OverrideColor = 4oLevel.OverrideLineStyle = ActiveDesignFile.LineStyles(4)oLevel.OverrideLineWeight = iWeightthenActiveDesignFile.Levels.Rewrite ActiveDesignFile.RewriteLevels MicroStationDGN.RedrawAllViews MicroStationDGN.SaveSettingsto try desperately to save them, close the file and reopen they all return to where they wereI have had to revert to using CadInputQueue.SendKeyin .....because that actually works
Hi Ben,
I have tested to modify the OverrideColor using VBA and did not notice a problem (used code example below ).But any V8 DGN file has a setting refleveloverrides to allow or permit permanent changes to the reference level overrides.You may want to check a dgn using the keyin "set refleveloverrides", this returns the value On or Off.If this is set to Off, changes are lost with reopening file.To enable this, the keyin "set refleveloverrides on" can be used (save settings is also required) If this does not help, please provide a full code example - thanks.
Here the simple code example I have used for testing with sample dgn file:
Sub reflevelsoverridetest() Dim oLvs As levels Dim oLv As level Dim oAtt As Attachment Dim i As Long For Each oAtt In ActiveModelReference.Attachments Set oLvs = oAtt.levels i = 0 For Each oLv In oLvs oLv.OverrideColor = i Mod 255 i = i + 1 Next oLvs.Rewrite Next End Sub
Best regards,
Artur
