Is there any API for Item Type property lookup tables?
Is CustomProperty.DefaultValueExpression related to this or does that do something else?
Hi Jon,
Jon Summers said:Is there any API for Item Type property lookup tables?
I have not found anything where ItemTypes lookup tables are mentioned, but...
Jon Summers said:Is CustomProperty.DefaultValueExpression related to this or does that do something else?
I did not write any test code, but it looks like a right method that should be tested first.
It's known I prefer to use pure EC approach, at least to understand using what EC features ItemTypes are implemented. I did some quick tests that confirms my former findings:
My assumption is that:
If I am wrong, look up method definition can be easily added to existing EC property using CalculatedECProperty.
With regards,
Jan
In Update 14 SetExpression() API is introduced for setting up Expression values on CustomProperty class.
For the usage details you can refer following link :
https://communities.bentley.com/products/programming/microstation_programming/b/weblog/posts/working-with-itemtype-ec-expression-using-managed-native-and-com-api-s-upcoming-feature-in-microstation-connect-edition-update-14
Answer Verified By: Jon Summers
