We develop application in french language so we often use accentuated characters.
Since we have migrated our application in Connect Edition, we have problem of displaying our accentuated characters in our dialog boxes.
In fact, we have redefine a resource and our application read the resource to display it in the dialog box:
The resource is defined like this
AlmToolsDlgBoxRsc DIAGID_PlDrapTexte = { DEFALMBOX_DockFlottante, 78*XC,30*YC, "", "", { {{1*XC, 0.25*YC, 20*XC, 0}, Label, 0, ON, ALIGN_LEFT, "Caractéristique", "", 0}, {{1*XC, 1.5*YC, 27*XC, 0}, ComboBox, CBXID_PlDrapNature1, ON, 0, "", "", 0}, {{29*XC, 1.5*YC, 12*XC, 0}, ComboBox, CBXID_PlDrapClasseReseau1, ON, 0, "", "", 0},
Here is how we have redefine the resource
typedef struct { Sextent extent; RscType type; RscId id; UInt32 attributes; UInt64 itemArg;#if defined (resource) Utf8Char label[]; /* label de l'item */ char auxInfo[]; /* access string */ long auxattr; /* attribut auxiliaire */#else long labelLength; Utf8Char label[1];#endif } DlgItemRsc;
Here is the part of code to display the items in the dialog box
DialogItem *itemP = mdlDialog_itemLoad(diagP, zmrscitemP, 0, ggAlmOwnerMDP, -1, NULL); if (itemP != NULL) { mdlDialog_itemDraw(diagP, itemP->itemIndex); }
Do you have an idea why our accentuated characters are not correctly displayed.
Thanks for your help
Hervé
Hi Hervé,
Please have a look at this post:
https://communities.bentley.com/products/programming/microstation_programming/f/microstation-programming---forum/111514/connect---c-problems-with-special-danish-characters-in-dialogbox-es?ReplySortBy=CreatedDate&ReplySortOrder=Ascending
I hope it will you...
Regards, Evan
Answer Verified By: Robert Hook
Hi Evan,
Thank's a lot, it's the solution!
I looked for a post concerning the read of the resource but the problem was elsewhere...
Best regards,
