Hi everybody,
I use the function mdlClip_element with a non persistant element for the inputEdP and the function crashes.In the follwing code, DynAccroElmDscrP is non persistant.
if (mdlClip_getFence(clipP) == SUCCESS) { // DynAccroElmDscrP is a correct linestring element // the following line crashes mdlClip_element(InsideElmDynDscrPP, OutElmDynDscrPP,DynAccroElmDscrP, ACTIVEMODEL, clipP.get(), vue); }
With the following code, everythink is ok
if (mdlClip_getFence(clipP) == SUCCESS) { mdlElmdscr_addByModelRef(DynAccroElmDscrP, ACTIVEMODEL); mdlClip_element(InsideElmDynDscrPP, OutElmDynDscrPP, DynAccroElmDscrP, ACTIVEMODEL, clipP.get(), vue); }
But the problem is that I don't want to add this ElementDescr immediatly.
Thank's for your help!
Hervé
Herve,
Did you ever come up with a solution to this problem. I am having the same problem.
Christine Joy said:I am having the same problem
In which version of MicroStation?
Herve Cuzon said:DgnPlatform::EditElementHandle ehh(DynAccroElmDscrP, false,true);
I find the bools in the ElementHandle constructor hard to remember, and prefer to document them like this...
bool
ElementHandle
const bool Owner = true; const bool IsUnmodified = true; DgnPlatform::EditElementHandle ehh(DynAccroElmDscrP, !Owner, IsUnmodified);
Herve Cuzon said:ehh.GetElementDescrP()
A comment in the MicroStationAPI tells us: This call should only be used where necessary, and should be avoided in readonly. Use PeekElementDescrCP to see whether this ElementHandle already has an MSElementDescr.
mdlClip_element(InsideElmDynDscrPP, OutElmDynDscrPP, ehh.PeekElementDescrCP(), ACTIVEMODEL, clipP.get(), view);
Without seeing your code it's hard to comment further.
MicroStation V10.14.0.109 This is legacy v8i code that we are just trying to get to work in V10. mdlClip_isElemInside works perfectly when the element is a persistent element. It only crashes on elements that have not yet been added to the design file. I will try using EditElementHandle, but I thought Herve said that crashed too.
Christine Joy said:mdlClip_isElemInside works perfectly when the element is a persistent element. It only crashes on elements that have not yet been added to the design file
As Brien Bastings commented, a persistent element has a DGN model associated with it. A newly-created element in memory does not have a DGN model assigned.
One reason for suggesting use of an ElementHandle is that the DGN model can be specified in its constructor, or assigned later. An ElementHandle with a DGN model reference should behave in the same way as one obtained from a persistent element.
If you're using a raw MSElementDescr then you can assign a DGN model reference to its dgnModelRef member...
MSElementDescr
dgnModelRef
MSElementDescrP inputElement = ... inputElement->h.dgnModelRef = ACTIVEMODEL;
Please post your code for further analysis.
Answer Verified By: Robert Hook
Thank you Jon!
inputElement->h.dgnModelRef = ACTIVEMODEL; Fixed my problem
