I must be missing something. all i want to be able to do is take all selected text elements and bold them. But i appears this is only possible if a text style has not been used
there is apparently no way to do this in bulk using any microstation tools. the modify text attributes does not have bold as an option. the best you can do is update a text style and save that, then switch all the text to that text style. but this causes problems because we have special symbols in a different font but then regular text uses aerial. so applying a text style switches all text to the font specified in the text style which then makes the special symbols display as a box (as aerial font doesnt have that symbol). So i thought why not just loop through selected elements and bold it. but my code below will only bold the text if the text style is set to none.
I can open the text editor for a given text element and hit the bold bottom to bold the text no matter what textstyle is set and that text style itself is not modified. (that would be bad if it did because then all elements using that text style would get updated automatically.) so its possible to achieve what i want via text editor but i need to do that in bulk.
So something as basic as bulk bolding text doesnt seem possible
here is my code.
Dim oEE As ElementEnumerator Dim intNumSel As Integer intNumSel = 0 Set oEE = ActiveModelReference.GetSelectedElements Do While oEE.MoveNext If oEE.Current.IsTextElement Or oEE.Current.IsTextNodeElement Then 'count the elements intNumSel = intNumSel + 1 If oEE.Current.IsTextElement Then oEE.Current.AsTextElement.TextStyle.IsBold = True oEE.Current.Rewrite ElseIf oEE.Current.IsTextNodeElement Then Dim eeText As ElementEnumerator Set eeText = oEE.Current.AsTextNodeElement.GetSubElements Do While eeText.MoveNext eeText.Current.AsTextElement.TextStyle.IsBold = True eeText.Current.Rewrite Loop oEE.Current.Rewrite Else End If Else End If Loop
any ideas
I remember there are some bugs for directly changing textstyle for TextElement in CE. A workaround is using ActiveSettings.TextStyle. Below is a sample for this:
Sub SetTextBold() Dim normTextElem As TextElement, boldTextElem As TextElement Set normTextElem = ActiveModelReference.GetElementByID(DLongFromLong(2906)) ActiveSettings.TextStyle = normTextElem.TextStyle ActiveSettings.TextStyle.IsBold = True Set boldTextElem = CreateTextElement1(Nothing, normTextElem.Text, normTextElem.Origin, normTextElem.Rotation) ActiveModelReference.ReplaceElement normTextElem, boldTextElem End Sub
