I need read data from dgn file, for example list of levels, from windows application.
The simple workflow, user start windows app, browse to dgn and get list of levels.
The microstation is installed in the user computer, but this function will be started not in microstation.
I need start process, read file and get information.
Thank you.
Best regards
Darius
Hi Darius,
you can access MicroStation process from external application using Interop library.
I recommend to read MicroStation VBA help delivered with MicroStation. It contains information about accessing MicroStation from external processes and both VBA and Interop are based on the same API.
With regards,
Jan
P.S. Please read and follow the forum best practices. Information about a version is missing, to know whether you plan to use V8i or CONNECT Edition can be important.
