When building C++ examples for the update 12 SDK it fails with the following error:
-MANIFESTFILE:C:\Users\doug\AppData\Local\Temp\Bentley\MicroStationSDK\objects\ModelExample.dll.ManifestC:\Users\doug\AppData\Local\Temp\Bentley\MicroStationSDK\objects\ModelExample.obj C:\Users\doug\AppData\Local\Temp\Bentley\MicroStationSDK\objects\ModelExampleHelper.obj B:\Apps\Bentley\library\bentley.lib B:\Apps\Bentley\library\BentleyAllocator.lib B:\Apps\Bentley\library\mdlbltin.lib B:\Apps\Bentley\library\RmgrTools.lib B:\Apps\Bentley\library\BentleyGeom.lib B:\Apps\Bentley\library\DgnPlatform.lib B:\Apps\Bentley\library\ECObjects.lib B:\Apps\Bentley\library\dgnview.lib gdi32.lib user32.lib kernel32.lib C:\PROGRA~2\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\lib\x64\msvcrt.libB:\Apps\Bentley\library\mdlbltin.libLINK : fatal error LNK1181: cannot open input file 'C:\PROGRA~2\Microsoft.obj'BMAKE: call trace line: 414, B:\Apps\Bentley\mki\dlmlink.mki line: 106, B:\Apps\Bentley\examples\Model\ModelExample\ModelExample.mkeMon Nov 04 23:23:11 2019, elapsed time: 0:00
Clearly the space in the path:
Is causing problems. I'm guessing it needs to be quoted somewhere, but I have been unable to locate where it is specified.
Hi Douglas,
Douglas Wood said:with the following error:
Please use Insert > Insert code tool when you share any code, log or other output. To place it as unformatted text makes it more complicated for reading.
Douglas Wood said:When building C++ examples
It look like you use quite unusual installation location and not default setup, but it's not the source of the discussed problem.
Douglas Wood said:I'm guessing it needs to be quoted somewhere, but I have been unable to locate where it is specified.
You are correct, it's Microsoft linker feature it does not support spaces in path correctly.
Bmake expects 8.3 naming convention is enabled on used drives. Maybe on you C (system) volume, the 8.3 naming is not enabled? You can search Internet for details, but how to check whether the naming is enabled is e.g. here, how to change it is here.
I am not sure where exactly the path to the lib is built, it would require to create verbose log (-v switch) and to check how proper mke / mki file is implemented. Bmake works with 8.3 convention, so maybe to enclose the path to quotes, which is alternative to 8.3 naming, is not possible, not sure.
With regards,
Jan
I have here a script originally from Robert Hook, to create DOS 8.3 format. This helps us a lot with bmake.
@ECHO OFF ECHO. ECHO. ECHO ======================================================== ECHO == Show mangled (DOS 8.3 format) path and file name ECHO == of path provided, ECHO == or current directory if no arg provided ECHO ======================================================== :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: :: mangled :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: ECHO. ECHO. IF /i {%1}=={} ( CD ECHO. FOR /f "tokens=*" %%D IN ('cd') DO ECHO %%~sD ) else ( ECHO %1 ECHO. FOR %%A IN (%1) DO ECHO %%~sA ) ECHO. ECHO.
Mit freundlichen Grüßen / Best regards Volker Hüfner
| AB_DATE Engineering Software | ab-date.de |
Douglas Wood said:the space in the path: C:\PROGRA~2\Microsoft Visual Studio\2017\Professional\VC\Tools\MSVC\14.16.27023\lib\x64\msvcrt.lib Is causing problems. I'm guessing it needs to be quoted somewhere, but I have been unable to locate where it is specified. BMAKE: call trace line: 414, B:\Apps\Bentley\mki\dlmlink.mki
Look in the MDL Include file dlmlink.mki. It fails at line 414. Do not even think about editing that file!
dlmlink.mki
Those of us who have been doing this for a while have accommodated ourselves to bmake's foibles. For example, you might think about reinstalling Viz Studio to a location without spaces in folder names.
Jan Šlegr said:Maybe on you C (system) volume, the 8.3 naming is not enabled?
Good point! But why has Program Files(x86) been converted to PROGRA~2 but Microsoft Visual Studio remains unshortened?
Program Files(x86)
PROGRA~2
Jon Summers said:But why has Program Files(x86) been converted to PROGRA~2 but Microsoft Visual Studio remains unshortened?
That's very good question :-)
I do not know too much about how 8.3 naming works, but I remember it was mentioned in some discussion that the naming enable/disable does not mean that all names are affected immediately, but they are generated when created. So maybe it's because it was enabled/disabled before/after Visual Studio was installed?
System administrator should provide first insight how Windows are configured. Also to use fsutil tool can help to obtain more information about used configuration..
Hi Douglas Wood,
Can you confirm, zip and provide the following output?
Build verbose will create a single detailed build log (OS environment variables and verbose build log) so we can identify the first point where a configuration issue or error is occurring, hinting on where a possible fix may be needed.
Thank you in advance,Bob
