After loading a password protected .mvba file none of the macros in the project display in the macros drop-down list. Loading non-password protected projects all of the macros are displayed in the list. Even entering the password to unlock the protected project the macros are not displayed.
The only way for a user to run a macro from the protected vba is to issue the vba run key-in.
Hi Rod Wing,
Artur Goldsweer recently posted this to be an issue and filed Defect 1051127.
HTH,Bob
I'm not getting those errors, but the defect is probably related.
Rod WingSenior Systems Analyst
I have checked this in update 14 and I still can't see the macros from protected mvba's in the macro list.
Listed as resolved in U16.1 but it is not fixed even in U16.3. Still without giving password Dialog doesn't list password protected VBA.
658724 Resolved issue with Macros Dialog not listing password protected VBA projects.
Hi Oto,
I have checked this with U16.3 and can confirm this issue is not fixed for the macros dialog, only the VBA projects dialog is fixed.Will check further for details and let you know.
Thanks for reporting this.
Best regards,Artur
