Connect Version 13 C# Programming - ScanCriteria
Hello to All, I am having issues with ScanCriteria scanning and finding elements, I have attached the code below:
Any help would be appreciated.  In vb.net coding I used the Bentley.Interop.MicroStationDGN assembly which is a different scan process. I would like to use the Bentley.DgnPlatformNET assembly in my C# programming.
Thank you, Donna Rodrick
using Bentley.DgnPlatformNET;
using Bentley.DgnPlatformNET.Elements;
namespace SheetManager
 public partial class CtSheetManager : Form
    //other code
    List<BDPN.Elements.Element> scanEls = new List<BDPN.Elements.Element>();
    scanEls.Capacity = 100;
    using (ScanCriteria scanC = new ScanCriteria())
        List<MSElementType> elementTypes = new List<MSElementType>
            MSElementType.Text
        scanC.AddElementTypes(elementTypes);
        elementTypes.Clear();
        List<DgnElementClass> classTypes = new List<DgnElementClass>
	        DgnElementClass.Construction
        scanC.AddClassTypes(classTypes);
        classTypes.Clear();
        scanEls = scanC.Scan(dgnModel);
    //more code
