[CONNECT U13] DependencyManager: When the Root Element status is changed (DEPENDENCY_STATUS_CHANGED) is the "pre-changed" root element available?
When a Root Element of a Dependency Linkage is modified, is the "pre-modified" version of that Root Element cached anywhere where one can obtain a ElementHandle to it?. The Dependent Element is passed into the OnRootsChanged() function, and one can use "dependencyLinkage.root.elemid[]" to get the Root Element(s), but these are the Root Element(s) AFTER they've been changed. Can you get the state of the element PRIOR to the current CHANGE?
My Root Element can be moved (positional change only) or modified (scaled/etc). It's the case where the Root's size is changed that it would be helpful to be able to have access to the original sized element.
Bruce
