I've migrated a VBA macro from V8i to CE Update 12 that places dimension elements.
In the V8i version this statement works without a problem to place the automatic text for the dimension element
elDim.PrimaryText = "*"
In CE U12 I get this error on the same statement.
If I replace the * with any other text value the statement works without a problem.
elDim.PrimaryText = "Dim Value"
Is this a defect in CE, or is there a new way to enter specify automatic text in a dimension element?
FYI...
If I locate an existing dimension element in a VBA that uses the automatic text the PrimaryText property returns * as expected.
I set it to a different text value successfully, then tried to change it back to the * and got the same error.
Rod WingSenior Systems Analyst
Hi Rod,
Rod Wing said:Is this a defect in CE, or is there a new way to enter specify automatic text in a dimension element?
it's the bug in my opinion, there is not any other / new way how to modify dimension text in VBA.
Unfortunately there is no property handler available (dimension text is not displayed in Element Properties dialog), so I guess the only workaround available is to call native C++ function, which is not simple in general and even more complicated in this case, because structures are used as parameters in native API, not simple string.
With regards,
Jan
Hi Artur Goldsweer,
Can you review this post to confirm with a defect, provide recommendation, or if needed request a standard test case to ensure reproduciblility?
Thank you in advance,Bob
I filed a service request. Service Request number7001014756
Hi Rod Wing,
thanks for reporting this issue, Defect # 1073627 is filed to address this issue and the Service Request is linked to the Defect.
Best regards,
Artur
I have tested this in CE U16 and it has been fixed.
Answer Verified By: Rod Wing
