C# MSCE Update 13 Set named model to be the active model in the current MicroStation session
C# Microstation CONNECT Update 13
I have a .dgn file loaded in the current session of MicroStation which contains a design model named "default" and a sheet model named "Sheet1".
How can I set the active model programmatically by the name "Sheet1" so that it is the currently active model for the user in the current MicroStation session?
I can do it crudely by sending a key-in command to activate the model, but was hoping I could do this more directly with .NET.
Thank you
Stephen
