I have attached 2 MicroStation Connect Edition files represention a double curved bridge deck defined in our IBDAS model by BOXES, each BOX defined by 6 box sides each represented by NURBS-surface:
1. SmartSolid.dgn : each box represented by a SmartSolid.
2. SmartSolidApiUnite.dgn: each box represented by a SmartSolid. Boolean Union in SDK are used to union all boxes. Boxes are added to unions one by one and in case a box cannot be added to any existing uniona new union is introduced. It is very easy to see that the SDK dosent work. Same of the boxes disappear - Why? The SDK operations does not reflect error conditions.
You can try to simulate the SDK process just by interactively do the same operations (Unite) in MicroStation Connect Edition using SmartSolid.dgn.SmartSolidApiUnite.dgnSmartSolid.dgn
BR
Peder
Hi Jan,
Sorry, we are using:
MicroStation Connect Edition ver. 10.110036
and
MicroStation Connect Edition SDK ver. 10.130048
It seems like we are using an old version of MicroStation Connect Edition – and that is maybe the reason why we cant interactively unite the boxes – we have to update.
How do we set parameter Merge parametric solid = off in the SDK BooleanUnion?
I have listed our code below.
Thanks for helping us!
BR,
Selected code lines:
// sew sheets together as smart solid bvector<ISolidKernelEntityPtr> sewn; bvector<ISolidKernelEntityPtr> unsewn; succes= SolidUtil::Modify::SewBodies (sewn, unsewn, &tool.front(), tool.size (), 2.5e1,10); x=succes; DUMPV8("solid2",&x,6); x=sewn.size(); DUMPV8("sewn.size",&x,9); if (succes==0) // get element descriptor for smartsolid { x=jfirst; DUMPV8("jfirst",&x,5); if (jlast-jfirst > 0 ) { if (j == jfirst) uniontarget.push_back(sewn.front()); if (j==jfirst) surfdegene[j*6+1]=-10; if (j > jfirst) uniontool.push_back(sewn.front()); DUMPV8("solid3",&x,6); if (j == jfirst) kunion++; if (j > jfirst) { succes=SolidUtil::Modify::BooleanUnion (uniontarget.front(), &uniontool.front (), uniontool.size ()); x=succes; DUMPV8("solid4",&x,6); if (succes==0) surfdegene[j*6+1]=-10; if (succes == 0) kunion++; if (succes!=0) jlastnew=j; if (succes==0) kadd++; } } else { uniontarget.push_back(sewn.front()); kunion++; }
Hi Peder,
Peder Frandsen Jakobsen said:Sorry, we are using:
thanks for providing the details :-)
Accordingly to the best practices, may I ask you to:
Peder Frandsen Jakobsen said:MicroStation Connect Edition ver. 10.110036 and MicroStation Connect Edition SDK ver. 10.130048
Opps ... are aware how big fault it is, especially when you develop native code application?
One from the most important rule in MicroStation C++ development is to use the same version of MicroStation and MicroStation SDK!
Peder Frandsen Jakobsen said:How do we set parameter Merge parametric solid = off in the SDK BooleanUnion?
I have no idea :-(
I guess somebody from Bentley (Brien Bastings?) can provide further details...
With regards,
Jan
