[CONNECT U10 C++] Upgrading a call to V8i mdlText_create with a CONNECT TextBlock
I am replacing a call to mdlText_create with a TextBlock. I am trying to set the location of the text with the SetUserOrigin method, but the text is not created at that location.  Am I using the correct method or am I doing something else wrong?  I am including the code I use to create a text element and a line element. The line is created in the correct location but the text is not.
Private void text_test()
	Dpoint3d  ptTemp;
	ptTemp.x = 13307591.40;
	ptTemp.y = 994947.00;
	ptTemp.z = 291.70;
	//create text element
	TextBlockPropertiesPtr tbProps = TextBlockProperties::Create(*DgnTextStyle::GetActive(), *ISessionMgr::GetActiveDgnModelP());
	tbProps->SetIsViewIndependent(true);
	ParagraphPropertiesPtr paraProps = ParagraphProperties::Create(*DgnTextStyle::GetActive(), *ISessionMgr::GetActiveDgnModelP());
	paraProps->SetJustification(Bentley::DgnPlatform::TextElementJustification::CenterBaseline);
	RunPropertiesPtr runProps = RunProperties::Create(*DgnTextStyle::GetActive(), *ISessionMgr::GetActiveDgnModelP());
	TextBlockPtr textBlock = TextBlock::Create(*tbProps, *paraProps, *runProps, *ISessionMgr::GetActiveDgnModelP());
	textBlock->GetRunPropertiesForAddR().SetFontSize(DPoint2d::From(10.0,10.0));
	textBlock->SetUserOrigin(ptTemp);
	textBlock->AppendText(L"test");
	EditElementHandle eeh;
	TextHandlerBase::CreateElement(eeh, NULL, *textBlock);
	MSElementP tmpElement;
	tmpElement = eeh.GetElementP();
	mdlElement_display(tmpElement, DgnPlatform::DRAW_MODE_Normal);
	mdlElement_add(tmpElement);
	//create line element
	Dpoint3d        testLine[2];
	testLine[0].x = ptTemp.x;
	testLine[0].y = ptTemp.y;
	testLine[0].z = ptTemp.z;
	testLine[1].x = ptTemp.x + 1.0;
	testLine[1].y = ptTemp.y;
	testLine[1].z = ptTemp.z;
	mdlLine_create(&element, NULL, testLine);
	mdlElement_display(&element, DgnPlatform::DRAW_MODE_Normal);
	mdlElement_add(&element);
Thanks for your help.
Warren
  • Please refer my below test code snippet. It can create text element in correct location running on MSCE-U13.
    	DgnModelP       pActiveModel = ISessionMgr::GetActiveDgnModelP();
    	TextBlockPropertiesPtr  pTBProp = TextBlockProperties::Create(*pActiveModel);
    	ParagraphPropertiesPtr  pParaProp = ParagraphProperties::Create(*pActiveModel);
    	pParaProp->SetJustification(TextElementJustification::LeftBaseline);
    	DgnTextStylePtr         pStyle = DgnTextStyle::GetActive();
    	RunPropertiesPtr        pRunProp = RunProperties::Create(*pStyle, *pActiveModel);
    	TextBlockPtr pTextBlock = TextBlock::Create(*pTBProp, *pParaProp, *pRunProp, *pActiveModel);
    	pTextBlock->SetUserOrigin(DPoint3d::From(10000, 10000, 0));
    	pTextBlock->AppendText(L"TestString");
    	if (TEXTBLOCK_TO_ELEMENT_RESULT_Success ==
    		TextHandlerBase::CreateElement(eeh, nullptr, *pTextBlock))
    		eeh.AddToModel();
  • Thanks for the help.  I made a few changes to my test case to match your example, but I still had the same problem.  I can create a line at the correct location, but when I try to create text it is created at a location with very large X and Y values (greater than 21,000,000).  I think memory is being corrupted or possibly a value needed by the text routine is not being set.
  • Have you taken your UOR values:
    Dpoint3d ptTemp;
    ptTemp.z = 291.70;
    and converted them back to whatever Master/Sub units you are using. Does that result match the location where your text is being placed? Remember, the DPoint3d you supply is in UORs, not Master Units...
Reply Children
