Good evening,
in the attacched file I created several models. Some of them have as name a number. As you can see those one are 42.
I created them "manually", copying the model, renaming it and moving the content (in x and y).
I wish to reach number 250, but doing it manually would cost a lot of time.
Is it possible do it with a macro? If yes could you please suggest me the way or share some code to help me?
I tried to record a macro without having useful help.
Thanks a lot,
P
smartSketch.dgn
Workflow, how it can be solved when moved will be references attachments in Default model, not content in individual models:
Prerequisities:
Step1: Generate models (VBA)
CadInputQueue.SendKeyin "model active default" Dim source As ModelReference Set source = ActiveDesignFile.Models("Template") Dim index As Integer For index = 1 To 300 Dim model As ModelReference Set model = ActiveDesignFile.Models.Copy(source, CStr(index)) DoEvents Next index DoEvents
Step 2: Attach references and move (pseudocode)
CadInputQueue.SendKeyin "model active default" For index = 1 To 300 attach reference "index" calculate X = f(index) calculate Y = f(index) move reference by x,y Next index
Jan
Ok, thanks a lot Jan.
I transformed your code as follow:
Sub AddModels() Dim source As ModelReference Dim i As Integer Dim ModelToBeCopied As Integer CadInputQueue.SendKeyin "model active default" For i = 41 To 50 Dim model As ModelReference ModelToBeCopied = i - 10 Set source = ActiveDesignFile.Models(CStr(ModelToBeCopied)) Set model = ActiveDesignFile.Models.Copy(source, CStr(i)) DoEvents Next i DoEvents End Sub
1. But I obtained "Temp Views" and I'd prefer "Views". How could I do?
2. I tried to attach in "Default" model a model already attached (as if it were the "Template" of your suggestion) and then move it ( the intention was to do some tests on the levels to verify that a single template model could be used and then copy it in different positions). So I attached again Model "31" in the "default" model and I tried to move it....but nothing happens: the frame (Hilite mode: Boundaries) of the reference selection does not appear, nothing appears when the reference is moved, etc... Why? :-O
Thanks.
Best regards,
Paolo
Paolo Maggiani said:Macro to add models
It looks like your original question is answered. Your new questions should be in new posts.
Paolo Maggiani said:I obtained "Temp Views" and I'd prefer "Views"
Please explain what you mean. Your code copies models, not views.
Paolo Maggiani said:I attached again Model "31" in the "default" model and I tried to move it....but nothing happens
Show us your code!
