[VBA][SS3] "Nested Attachments: No Nested" after new opening file
Good moring,
yesterday I ran following code:
Sub AddReferences()
    Dim p3dMasterPoint As Point3d
    Dim p3dReferencePoint As Point3d
    Dim atcReference As Attachment
    Dim strFileSpec As String
    Dim i As Integer
    Dim j As Long
    Dim k As Long
    Const constMoveAlongX = 4700
    Const constMoveAlongY = 3386
    k = 1
    strFileSpec = Application.ActiveDesignFile.FullName
    For i = 1 To 50
        For j = 1 To 10
            p3dMasterPoint.X = constMoveAlongX * (j - 1)
            p3dMasterPoint.Y = constMoveAlongY * (k - 1)
            p3dMasterPoint.Z = 0#
            p3dReferencePoint = Point3dZero
            Set atcReference = ActiveModelReference.Attachments.Add(strFileSpec, ".Template", CStr((i - 1) * 10 + j), "Sketch n° " & CStr((i - 1) * 10 + j), p3dMasterPoint, p3dReferencePoint)
            atcReference.NestLevel = 1
        Next j
        k = k - 1
        j = 0
    Next i
End Sub
and it worked well.
This morning I opened again the file but I didn' find any attachments on "Default" model. So I opened References Dialog window and I Found all references. But in the Attachment Settings window I saw Nested Attachments as "No Nesting". Please, see the attached image.
Why? How can I solve it with code? I wish to avoid setting as "Live Nesting" manually for 500 references.
A second question.
When i launched the code, it blocked microstation ... as if it were looping. So I used debug mode, running only one j loop at a time without problems. I just noticed, going forward, each attachement was slower and slower. Could you kindly tell me the reason and possibly suggest the solution?
Thanks a lot,
Paul
  • Hi Paolo,
    please, never ask more questions in one post! Especially when they are about very different topics (nesting and performance in this case).
    Why?
    I do not see any rewrite when NestingLevel is set.
    I guess it's not any surprise ;-)
    Without testing case, it's hard to guess. Doing 500 iterations of design file content has many consequences, especially when VBA is used (VBA is like external process, interacting through COM API).
    Always, when more iterations are done, you should call DoEvents regularly to allow OS and host application to do their home works and maintenance tasks. It's not directly related to performance, but overall communication between code and host application.
    I also recommend to stop using (I guess I mentioned it already earlier) the way to declare everything at the beginning. In my opinion it's very bad practice, leading to dirty and unstructured code and consequently to more errors. Declared variable when it's needed, never earlier.
    In addition to better readability, it helps interpreter (and compiler in other languages) to better analyze / distinguish when the variable (and allocated memory) is used and when it can be cleared.
    Sub AddReferences()
        Dim k As Long
        k = 1
        Dim i As Integer
        For i = 1 To 50
            Dim j As Long
            For j = 1 To 10
                Set atcReference = ActiveModelReference.Attachments.Add(strFileSpec, ".Template", CStr((i - 1) * 10 + j), "Sketch n° " & CStr((i - 1) * 10 + j), p3dMasterPoint, Point3dZero)
                ' I think this is missing in your code
                atcReference.Rewrite
            Next j
            k = k - 1
            j = 0
        Next i
    End Sub
    With regards,
      Jan
  • please, never ask more questions in one post! Especially when they are about very different topics
    I'll do.
    I'll do and I did in this case: it works better. :-)
    I'll do (but it couldn't be easy)
    Thanks a lot.
    P
  • I'll do (but it couldn't be easy)
    It's much easier than you think! :-)
    For all new code (the old one can be kept untouched) use Dim just before it's used. When this rule is applied with another crucial rule - to write very short methods, every with single responsibility (up to 10 lines) - one from consequences is that it's necessary to use only a few variables in every subroutine or function.
    With regards,
      Jan
