Dear all, good day.
I have a cell containing an element of type Surface(18).
I cannot understand how to navigate through its subelements.
Here it is visual basic code:
Public Sub NavigateThroughSurface( ByVal oApplication As Bentley.Interop.MicroStationDGN.Application ) Dim oEnumerator As Bentley.Interop.MicroStationDGN.ElementEnumerator = oApplication.ActiveModelReference.Scan
While oEnumerator.MoveNext Dim oElement = oEnumerator.Current If Not oElement.IsCellElement Then Continue While
Dim oCellElement As Bentley.Interop.MicroStationDGN.CellElement = oElement.AsCellElement Dim lSubElementEnumerator As Bentley.Interop.MicroStationDGN.ElementEnumerator = oCellElement.GetSubElements While lSubElementEnumerator.MoveNext Dim oSubElement = lSubElementEnumerator.Current If oSubElement.Type = Bentley.Interop.MicroStationDGN.MsdElementType.Surface Then 'I do not find any "oSubElement.AsSurface" function... 'I have already done several tries, but without success:
'!!!!following statement throws exception: Dim oBsplineSurfaceElement As Bentley.Interop.MicroStationDGN.BsplineSurfaceElement = oSubElement.AsBsplineSurfaceElement
'!!!!following statement throws exception too: Dim lSolids As Bentley.Interop.MicroStationDGN.ElementEnumerator = oApplication.SmartSolid.ConvertToSmartSolidElement(oSubElement)
'?????????So how I can point to the surface itself and navigate through its subelements????????? End If End While End While End Sub
Thanks in advance.
Roberto
Italy
Hello Roberto,
Do you want to extract the parameters of this surface element? If so, please refer to below test code. It depends Jon's revised DGN file.
Declare Function mdlSurface_extractRevolution2 Lib "stdmdlbltin.dll" (ByRef boundaryEdPP As Long, ByRef centerP As Point3d, ByRef axisP As Point3d, ByRef sweepAngleP As Double, ByVal surfaceEdP As Long) As Long Sub GetParametersFromSurface() Dim mySurface As Element, myBoundary As Element Set mySurface = ActiveModelReference.GetElementByID(DLongFromLong(4090)) Dim surfaceEdP As Long, boundaryEdP As Long Dim center As Point3d, axis As Point3d Dim sweepAngle As Double surfaceEdP = mySurface.MdlElementDescrP mdlSurface_extractRevolution2 boundaryEdP, center, axis, sweepAngle, surfaceEdP MsgBox "center=(" & center.X & "," & center.Y & "," & center.Z & "), sweepAngle=" & sweepAngle Set myBoundary = MdlCreateElementFromElementDescrP(boundaryEdP) If myBoundary.Type = msdElementTypeArc Then Dim myArc As ArcElement Set myArc = myBoundary.AsArcElement MsgBox "boundary center=(" & myArc.CenterPoint.X & "," & myArc.CenterPoint.Y & "," & myArc.CenterPoint.Z & "), boundary sweepAngle=" _ & myArc.sweepAngle & ", boundary radius=(" & myArc.PrimaryRadius & "," & myArc.SecondaryRadius & ")" End If End Sub
The above VBA code works perflectly in 32-bit, but it does not work in Connect (64-bit).
This is the VBA code "translated" into 64-bit environment:
Option Explicit Declare PtrSafe Function mdlSurface_extractRevolution2 Lib "stdmdlbltin.dll" ( _ ByRef boundaryEdPP As LongLong, _ ByRef centerP As Point3d, _ ByRef axisP As Point3d, _ ByRef sweepAngleP As Double, _ ByVal surfaceEdP As LongLong _ ) As DLong Sub GetParametersFromSurface() Dim mySurface As Element, myBoundary As Element Set mySurface = ActiveModelReference.GetElementByID(DLongFromLong(4090)) Dim surfaceEdP As LongLong, boundaryEdP As LongLong Dim center As Point3d, axis As Point3d Dim sweepAngle As Double surfaceEdP = mySurface.MdlElementDescrP mdlSurface_extractRevolution2 boundaryEdP, center, axis, sweepAngle, surfaceEdP MsgBox "center=(" & center.X & "," & center.Y & "," & center.Z & "), sweepAngle=" & sweepAngle Set myBoundary = Application.MdlCreateElementFromElementDescrP(boundaryEdP) If myBoundary.Type = msdElementTypeArc Then Dim myArc As ArcElement Set myArc = myBoundary.AsArcElement MsgBox "boundary center=(" & myArc.CenterPoint.X & "," & myArc.CenterPoint.Y & "," & myArc.CenterPoint.Z & "), boundary sweepAngle=" _ & myArc.sweepAngle & ", boundary radius=(" & myArc.PrimaryRadius & "," & myArc.SecondaryRadius & ")" End If End Sub
When I run the above code in PlantWise (Microstation Connect 64 bit) I get this msgbox:
And this is not the right answer, because the expected one (the right one obtained when the same modeled is opened in Microstation 32) is the following one:
Moreover, when I click on OK button to proceed, I get the following error and PlantWise aborts and close:
This is the link from where you can download the detailed log error generated: https://app.box.com/s/6v0ksnpohoskaypskc7s4lmfa89cfe7j
This is the PlantWise version we are using:
Please may you help us?
What are we doing wrong?
Roberto Cardosi said:This is the VBA code "translated" into 64-bit environment Declare PtrSafe Function mdlSurface_extractRevolution2 Lib "stdmdlbltin.dll" ( _ ByRef boundaryEdPP As LongLong, _ ByRef centerP As Point3d, _ ByRef axisP As Point3d, _ ByRef sweepAngleP As Double, _ ByVal surfaceEdP As LongLong _ ) As DLong
That's incorrect. Use something like this...
#If VBA7 Then Declare PtrSafe Function mdlSurface_extractRevolution2 _ Lib "stdmdlbltin.dll" ( _ ByRef boundaryEdPP As LongPtr, _ ByRef centerP As Point3d, _ ByRef axisP As Point3d, _ ByRef sweepAngleP As Double, _ ByVal surfaceEdP As LongPtr) _ As Long #Else Declare Function mdlSurface_extractRevolution2 _ Lib "stdmdlbltin.dll" ( _ ByRef boundaryEdPP As Long, _ ByRef centerP As Point3d, _ ByRef axisP As Point3d, _ ByRef sweepAngleP As Double, _ ByVal surfaceEdP As Long) _ As Long #EndIf
Where an MDL function uses pointers, the Long type is used for 32-bit VBA. Microsoft introduced the LongPtr type with 64-bit VBA. So change this...
Long
LongPtr
to this...
Dim surfaceEdP As LongPtr, boundaryEdP As LongPtr
Thanks Jon, but nothing is changed, same behaviour.
This is the new edited code:
Option Explicit #If VBA7 Then Declare PtrSafe Function mdlSurface_extractRevolution2 _ Lib "stdmdlbltin.dll" ( _ ByRef boundaryEdPP As LongPtr, _ ByRef centerP As Point3d, _ ByRef axisP As Point3d, _ ByRef sweepAngleP As Double, _ ByVal surfaceEdP As LongPtr) _ As Long #Else Declare Function mdlSurface_extractRevolution2 _ Lib "stdmdlbltin.dll" ( _ ByRef boundaryEdPP As Long, _ ByRef centerP As Point3d, _ ByRef axisP As Point3d, _ ByRef sweepAngleP As Double, _ ByVal surfaceEdP As Long) _ As Long #End If Sub GetParametersFromSurface() Dim mySurface As Element, myBoundary As Element Set mySurface = ActiveModelReference.GetElementByID(DLongFromLong(4090)) Dim surfaceEdP As LongPtr, boundaryEdP As LongPtr Dim center As Point3d, axis As Point3d Dim sweepAngle As Double surfaceEdP = mySurface.MdlElementDescrP mdlSurface_extractRevolution2 boundaryEdP, center, axis, sweepAngle, surfaceEdP MsgBox "center=(" & center.X & "," & center.Y & "," & center.Z & "), sweepAngle=" & sweepAngle Set myBoundary = Application.MdlCreateElementFromElementDescrP(boundaryEdP) If myBoundary.Type = msdElementTypeArc Then Dim myArc As ArcElement Set myArc = myBoundary.AsArcElement MsgBox "boundary center=(" & myArc.CenterPoint.X & "," & myArc.CenterPoint.Y & "," & myArc.CenterPoint.Z & "), boundary sweepAngle=" _ & myArc.sweepAngle & ", boundary radius=(" & myArc.PrimaryRadius & "," & myArc.SecondaryRadius & ")" End If End Sub
And again it pops up wrong data and then it aborts PlantWise...
Roberto Cardosi said: it pops up wrong data
With VBA and other APIs, angles are always in radians. You need to convert to degrees for human consumption...
MsgBox "boundary center=(" & CStr (myArc.CenterPoint.X) & "," & CStr (myArc.CenterPoint.Y) & "," & CStr (myArc.CenterPoint.Z) & _ "), boundary sweepAngle=" & _ CStr (Degrees (myArc.sweepAngle)) & _ ", boundary radius=(" & CStr (myArc.PrimaryRadius) & "," & _ CStr (.SecondaryRadius) & ")"
Roberto Cardosi said:I get the following error
You've run into a memory leak when using C function calls from VBA. That MDL function passes you a element descriptor, which is the profile of revolution. It points to allocated memory. You must free that memory before you exit your subroutine...
... mdlElmdscr_freeAll boundaryEdPP End Sub
You'll need to add these MDL declarations at the beginning of the VBA module...
#If VBA7 Then Declare PtrSafe Function mdlSurface_extractRevolution2 _ Lib "stdmdlbltin.dll" ( _ ByRef boundaryEdPP As LongPtr, _ ByRef centerP As Point3d, _ ByRef axisP As Point3d, _ ByRef sweepAngleP As Double, _ ByVal surfaceEdP As LongPtr) _ As Long Declare PtrSafe Sub mdlElmdscr_freeAll _ Lib "stdmdlbltin.dll" _ (ByRef elemDescrPP As LongPtr) #Else Declare Function mdlSurface_extractRevolution2 _ Lib "stdmdlbltin.dll" ( _ ByRef boundaryEdPP As Long, _ ByRef centerP As Point3d, _ ByRef axisP As Point3d, _ ByRef sweepAngleP As Double, _ ByVal surfaceEdP As Long) _ As Long Declare Sub mdlElmdscr_freeAll _ Lib "stdmdlbltin.dll" _ (ByRef elemDescrPP As Long) #End If
Jon, thanks again for your support, but it still does not work...
It seems not to be a problem regarding memory leaking and/or formatting output data...
In the following VBA code I added comments that better explain (I hope) the problems I encountered:
Option Explicit #If VBA7 Then Declare PtrSafe Function mdlSurface_extractRevolution2 _ Lib "stdmdlbltin.dll" ( _ ByRef boundaryEdPP As LongPtr, _ ByRef centerP As Point3d, _ ByRef axisP As Point3d, _ ByRef sweepAngleP As Double, _ ByVal surfaceEdP As LongPtr) _ As Long Declare PtrSafe Sub mdlElmdscr_freeAll _ Lib "stdmdlbltin.dll" _ (ByRef elemDescrPP As LongPtr) #Else Declare Function mdlSurface_extractRevolution2 _ Lib "stdmdlbltin.dll" ( _ ByRef boundaryEdPP As Long, _ ByRef centerP As Point3d, _ ByRef axisP As Point3d, _ ByRef sweepAngleP As Double, _ ByVal surfaceEdP As Long) _ As Long Declare Sub mdlElmdscr_freeAll _ Lib "stdmdlbltin.dll" _ (ByRef elemDescrPP As Long) #End If Sub GetParametersFromSurface() Dim mySurface As Element, myBoundary As Element Set mySurface = ActiveModelReference.GetElementByID(DLongFromLong(4090)) Dim surfaceEdP As LongPtr, boundaryEdP As LongPtr Dim center As Point3d, axis As Point3d Dim sweepAngle As Double surfaceEdP = mySurface.MdlElementDescrP mdlSurface_extractRevolution2 boundaryEdP, center, axis, sweepAngle, surfaceEdP MsgBox "center=(" & center.X & "," & center.Y & "," & center.Z & "), sweepAngle=" & sweepAngle 'the above msgbox should pop up following correct result: center={0,0,30} and sweepangle=3.14 (180 degree) 'instead it popped up the following wrong result: center={0,0,0} and sweepangle=0 'the following statement throws the exception log I previously linked 'and aborts PlantWise Set myBoundary = Application.MdlCreateElementFromElementDescrP(boundaryEdP) If myBoundary.Type = msdElementTypeArc Then Dim myArc As ArcElement Set myArc = myBoundary.AsArcElement MsgBox "boundary center=(" & CStr(myArc.CenterPoint.X) & "," & CStr(myArc.CenterPoint.Y) & "," & CStr(myArc.CenterPoint.Z) & _ "), boundary sweepAngle=" & _ CStr(Degrees(myArc.sweepAngle)) & _ ", boundary radius=(" & CStr(myArc.PrimaryRadius) & "," & _ CStr(myArc.SecondaryRadius) & ")" End If mdlElmdscr_freeAll boundaryEdP End Sub
I hope I was clear...
Taking things one step at a time, the following code successfully extracts the metrics of your cap element...
' --------------------------------------------------------------------- Public Function FormatPoint3d(ByRef pt As Point3d) As String Dim s As String Const Pattern As String = "#,##0.00" s = Format(pt.X, Pattern) & ", " & Format(pt.Y, Pattern) & ", " & Format(pt.Z, Pattern) FormatPoint3d = s End Function ' --------------------------------------------------------------------- Public Sub AnalyseType18(ByVal oHead As Element) Dim msg As String msg = "Analyse element type " & CStr(oHead.Type) ShowMessage msg, msg, msdMessageCenterPriorityDebug, False Debug.Print "Analyse element type " & CStr(oHead.Type) If (oHead.Type = msdElementTypeSolid Or oHead.Type = msdElementTypeSurface) Then Dim axis As Point3d Dim centre As Point3d Dim sweep As Double Const SUCCESS As Long = 0 Const NULL_PTR As LongPtr = 0 If (SUCCESS = mdlSurface_extractRevolution2(NULL_PTR, centre, axis, sweep, oHead.MdlElementDescrP)) Then msg = "Centre XYZ=" & FormatPoint3d(centre) & _ " Axis XYZ=" & FormatPoint3d(axis) & _ " Sweep Angle=" & CStr(Degrees(sweep)) ShowMessage msg, msg, msdMessageCenterPriorityDebug, False Debug.Print msg Else msg = "Unable to extract revolution parameters" ShowMessage msg, msg, msdMessageCenterPriorityWarning, True End If Else msg = "Invalid element for Type 18/19 analysis" ShowMessage msg, msg, msdMessageCenterPriorityWarning, True End If End Sub
The result, shown in the Message Center, is...
Centre XYZ=0.00, 0.00, 30.00 Axis XYZ=0.00, 0.00, 1.00 Sweep Angle=180
This procedure successfully extracts the boundary arc...
Sub AnalyseType18Boundary(ByVal oHead As Element) Dim msg As String msg = "Analyse element type " & CStr(oHead.Type) ShowMessage msg, msg, msdMessageCenterPriorityDebug, False Debug.Print "Analyse element type " & CStr(oHead.Type) If (oHead.Type = msdElementTypeSolid Or oHead.Type = msdElementTypeSurface) Then Dim axis As Point3d Dim centre As Point3d Dim sweep As Double Dim oBoundary As Element Dim elementAddress As LongPtr Const SUCCESS As Long = 0 If (SUCCESS = mdlSurface_extractRevolution2(elementAddress, centre, axis, sweep, oHead.MdlElementDescrP)) Then Set oBoundary = Application.MdlCreateElementFromElementDescrP(elementAddress) msg = "Boundary element type " & CStr(oBoundary.Type) ShowMessage msg, msg, msdMessageCenterPriorityDebug, False Debug.Print msg If oBoundary.IsArcElement Then Dim oArc As ArcElement Set oArc = oBoundary.AsArcElement msg = "Analyse arc element" ShowMessage msg, msg, msdMessageCenterPriorityDebug, False Debug.Print msg msg = "Centre XYZ=" & FormatPoint3d(oArc.CenterPoint) & _ " Sweep angle=" & CStr(Radians(oArc.SweepAngle)) & _ " Radius=" & CStr(oArc.PrimaryRadius) ShowMessage msg, msg, msdMessageCenterPriorityDebug, False Debug.Print msg Else msg = "Boundary is not an arc element" ShowMessage msg, msg, msdMessageCenterPriorityWarning, True End If Else msg = "Unable to extract revolution boundary" ShowMessage msg, msg, msdMessageCenterPriorityWarning, True End If Else msg = "Invalid element for Type 18/19 analysis" ShowMessage msg, msg, msdMessageCenterPriorityWarning, True End If End Sub
Note that I don't free memory — my previous advice was incorrect. Memory management is handled by the Element created by MdlCreateElementFromElementDescrP.
Element
