Hi MicroStation Experts,
I am working with some pure MDL code and saw the usage of some functions such as mdlInput_sendKeyin and mdlDialog_find.
I searched for their documentation from the .chm help files (MicroStationAPI, MicroStationVBA, MicroStationProgrammerGuide), but could not find them.
However, I found their definition/declaration in the MicroStation V8i SS4 SDK function definition files:
Is there any reference documents for these functions? such that I don't need to look at the .fdf files?
Thank you!
Sui
Hi Sui,
Jan already pointed out the required documentation. Even you found the documentation, you also need example codes to be able to understand better and use the function as you desired. Here is an example from MicroStation 95. It is old, but function is the same, I hope it will still work too. :) It comes from DeveloperWare 08.01.00.00 so it is compatible with MicroStation v8 series.
filepro.zip
Kind regards,
Sedat AlisAEC Technology Inc.
Thank you Sedat!
