I would like to know how I can make a preview image of a DGN file upon closing Microstation. Could someone please assist? I am programming in Visual Studio 2017 and C# on .Net Framework 4.6.1.
We pretty much have the same issue.
Our solution was to use KeyIns like "capture view". This worked fine in v8i.
e.g.
Utilities.ComApp.CadInputQueue.SendKeyin("capture view; selview " + view.Index.ToString());
Unfortunately the entire "capture" KeyIn group is missing in CONNECT. I've created a service ticket already.
Hi Pat,
PatB said:Unfortunately the entire "capture" KeyIn group is missing in CONNECT.
It's not quite true. The problem is CE is that screen capture application is not loaded.
It can be achieve modifying CE workspace to load scrncapt.ma automatically, or to add "load command" to key-in:
mdl silentload scrncapt;capture view
With regards,
Jan
