We have projects in two different CAD Standards that can be accessed in a single workspace. We would like to check that the user is using the correct standard when they open a file and one "flag" is the Model Properties for how linestyles should be scaled. We tried using code found from a post many years ago, but the results were inconclusive.
(GetCExpressionValue("modManInfoP->bLineStyleScaleEqualsAnnotationScale") = 1)
Always returns False. If I open and close the Model Properties dialog box, then it returns the correct value (either True or False).
Is there some other method that could be used in VBA?
TIA
Hi Chuck,
can you provide a picture what setting and what value do you mean?
With regards,
Jan
The Line Style Scale. This was added sometime after V8 was released and our original standard used the setting as shown here. The other option is to set it to Annotation Scale. When referencing files, you cannot mix files that these two settings are not synchronized.
Hi caddcop,
The MicroStation VBA Help Topic "Common Element Properties" provides an PropertyHandler example that should provide some linestyle properties that you are looking to use for your identification criteria.
ShowDisplayString oPH, "LineStyleParams.LSScale" ShowDisplayString oPH, "LineStyleParams.LSWidthMode" ShowDisplayString oPH, "LineStyleParams.LSStartWidth" ShowDisplayString oPH, "LineStyleParams.LSEndWidth" ShowDisplayString oPH, "LineStyleParams.LSGlobalWidth" ShowDisplayString oPH, "LineStyleParams.LSTrueWidth" ShowDisplayString oPH, "LineStyleParams.LSShiftMode" ShowDisplayString oPH, "LineStyleParams.LSDistancePhase" ShowDisplayString oPH, "LineStyleParams.LSFractionPhase" ShowDisplayString oPH, "LineStyleParams.LSCornerMode" ShowDisplayString oPH, "LineStyleParams.LSThroughCorner"
HTH,Bob
We are looking for model properties related to line styles. These are two different things.
My apologies for loosing context of "models" as being the source. MicroStation VBA PropertyHandlers work equally well for: Elements, Models, and DgnFiles; to list/access extended properties. I believe for a Model you want to examine the property "LineStyleScale". Here is sample output I can provide showing the available model properties and values that you can expect when using a PropertyHandler for a model
ModelReference Object Properties: [ModelReference] object id (N/A) has (44) defined properties: [1] Type: 0 [2] Is3D: 3D [3] IsMarkup: False [4] CanbePlacedAsCell: True [5] UpdateFieldsAutomatically: True [6] CanbePlacedAsAnnotationCell: False [7] IsActive: True [8] IsMaster: True [9] TreatAs3D: True [10] CellType: 8 [11] PropagateAnnotationScale: On [12] AnnotationScale: 1 [13] DesignScale: 1 [14] PaperScale: 1 [15] ModelId: 0 [16] Hidden: False [17] LineStyleScale: Annotation Scale [18] Format: 1 [19] MasterUnit: 2075 [20] SubUnit: 2125 [21] Accuracy: 0.123 [22] AngleReadoutFormat: ~DD.DDDD [23] AngleReadoutAccuracy: 0.12345678 [24] DirectionMode: Azimuth [25] DirectionBase: East [26] Direction: AntiClockwise [27] GlobalLineStyleScaleFactor: 1 [28] GridLock: False [29] GridMaster: 1 [30] GridReference: 10 [31] GridConfig: Ortho [32] GridAspect: 1 [33] IsometricLock: False [34] IsometricPlane: Top [35] ACSPlane: False [36] Name: 3D Metric Design Model [37] Description: [38] DefaultRefLogical: [39] MasterUnitLabel: m [40] SubUnitLabel: mm [41] Resolution: 10000 per Distance Meter [42] WorkingArea: 9.0072E+08 Kilometers [43] SolidArea: 1 Kilometers [44] SolidAccuracy: 1E-08 Meters [SUMMARY] (44 of 44) properties are available.
Answer Verified By: caddcop
Can you provide the code/project that generates this?
Let me see if I can safely isolate the minimal code needed (derived from the VBA PropertyHandler Example Help topic) since my MBVA project is a sprawling mess of lots of test functions and utility methods that are hard to gather as-is.
We can look at that topic and see what wrings out.
Here is an imperfect and mostly functioning version (though certainly needs more clean up, error handling and tuning) though should hopefully provide you with most of what you needed when simplified further.
Option Explicit Sub TEST_Models() Dim oModel As ModelReference For Each oModel In ActiveDesignFile.Models DisplayProperties oModel Next End Sub Sub DisplayProperties(o As Object) ' Validate input and object types If (IsObject(o) = False) Then Exit Sub Dim bDisplayInfo As Boolean, bIsValid As Boolean bIsValid = False ' FUTURE: Some objects (models, attachments, etc.) may require further tests/validation for processing. bDisplayInfo = True Dim oEl As Element, oModel As ModelReference, oAtt As Attachment, oDgn As DesignFile Dim sObjType As String, sObjId As String sObjType = TypeName(o) Debug.Print "[PROCESSING] ObjectType: " & sObjType Select Case sObjType Case "Attachment" Set oAtt = o bIsValid = oAtt.IsReadOnly sObjId = oAtt.DesignFile.FullName Case "DesignFile" Set oDgn = o bIsValid = oDgn.IsActive sObjId = oDgn.FullName Case "ModelReference" Set oModel = o bIsValid = oModel.IsReadOnly sObjId = oModel.Name Case Else ' Allow All MicroStation "Element" types If sObjType Like "*Element*" Then Set oEl = o bIsValid = oEl.IsValid sObjId = "Type: " & sObjType & ", ID: " & DLongToString(oEl.ID) If bDisplayInfo Then Debug.Print "Element Object: " & sObjType Else ' Explicitly report any unexpected object types for troubleshooting purposes. Debug.Print vbTab & "WARNING: Not Expecting Object Type Named - " & sObjType Exit Sub End If End Select ' Create property handler for object On Error GoTo ErrorHandler Dim oPH As PropertyHandler Set oPH = CreatePropertyHandler(o) ' Interate property handler Access Strings array Dim lCount As Long Dim lTotalProperties As Long Dim lTotalCanAccess As Long Dim sArr() As String, sMessage As String, sValue As String Dim bRtc As Boolean Dim oProperty As Variant sArr = oPH.GetAccessStrings lTotalProperties = UBound(sArr) + 1 If bDisplayInfo Then Debug.Print "[" & sObjType & "] object id (" & sObjId & ") has (" & lTotalProperties & ") defined properties: " If lTotalProperties <= 0 Then Exit Sub 'Function For Each oProperty In sArr ' Get AccessString item by its name, and respective value sMessage = "" sValue = "" lCount = lCount + 1 bRtc = oPH.SelectByAccessString(CStr(oProperty)) ' Attempt to get the value regardless of bRawValue to set warning sValue = oPH.GetValue If sValue = "" Then sValue = oPH.GetDisplayString ' Use display string as last resort If (bRtc = True And Len(sMessage) = 0) Then If Not IsEmpty(oPH) Then lTotalCanAccess = lTotalCanAccess + 1 sMessage = "[" & lCount & "] " & oProperty & ": " & sValue End If End If ' Report valid items and values. If (Len(sMessage) > 0 And bDisplayInfo = True) Then Debug.Print sMessage Next ' Provide summary if requested. If bDisplayInfo Then Debug.Print vbCrLf & "[SUMMARY] (" & lTotalCanAccess & " of " & lTotalProperties & ") properties are available." Exit Sub 'Function ' Unhandled error handler ErrorHandler: lTotalCanAccess = lTotalCanAccess - 1 Select Case Err.Number Case -2147218366 ' "Property - No Access" ' Return useful error details to display 'sMessage = "[" & lCount & "] ElID: " & DLongToString(oEl.ID) & ", Property: " & oProperty & ": " & ", Error: " & Err.Description sMessage = "[" & lCount & ", Property: " & oProperty & ": " & ", Error: " & Err.Description End Select Resume Next End Sub
Our testing shows that the properties available in V8i are far fewer than in CONNECT. My request was specific to V8i, so at this point, No Joy.
I wonder if there is a wrapper function I could use from MDL?
caddcop said:I wonder if there is a wrapper function I could use from MDL?
In the V8 era, VBA does a better job handling properties than MDL. To put that more bluntly, there isn't an MDL properties API that you can wrap.
Whether there's anything in the MicroStationAPI for V8i I don't know — but that's moot because you can't call C++ classes from VBA. Things have moved on substantially in CONNECT.
I have used what I assumed was a wrapper function in V8i, but maybe its something else. It had to do with sheet models and I needed to pass a pointer to an MDL function. The MDL documentation contain an error (imagine that) and eventually we got someone from Bentley to chime in. You were in on that discussion too.
I am a self taught VBA and MDL coder, and thanks to VBA, my MDL skills have unfortunately atrophied. And the good fortune of having a capable VBA programmer on staff also means my VBA skills are not called upon as often as needed to keep them sharp.
caddcop said:Our testing shows that the properties available in V8i are far fewer than in CONNECT
Yes, that's true. From this perspective, CE is much better and open.
Yes, you can ... and it was discussed already in this forum, even when not in relation to VBA.
Function mdlModelRef_getModelFlag() should be able to return Line Style Scale menu state (using MODELFLAG_LSSCALE_IS_ANNSCALE parameter), but I am not sure about retrieval of numeric value of the scale.
