Hello. My first post, so please be patient!I have problems using vba Function "ShowOpen". My vba runs fine on MicroStation V8i (SELCTseries 3), but it will not open Dialogbox for selecting file in a newer MicroSration version.Why don't this work in a newer MicroStation?I have created a VBA UserForm "frmGPS_indlas"In this form I have a push-button "Browse" (name) "cmdBrowseFile"In the code to this form I include a call to Function "ShowOpen":
Private Sub cmdBrowseFile_Click() Dim msg As String txtGPSfile = ShowOpen("Select GPS file", "CSV filer (*.csv)" + Chr$(0) + "*.csv", "All files (*.*)" + Chr$(0) + "*.*", "") If (Len(txtGPSfile) > 0) Then msg = "GPS fil '" & txtGPSfile & "'" Else msg = "No GPS file selected (Cancel)" End If ShowMessage msg, msg, msdMessageCenterPriorityInfo End Sub
And here we have "ShowOpen":
Public Function ShowOpen( _ strTitle As String, _ Optional strFilterDescr As String = "All files (*.*)", _ Optional strFilterSpec As String = "*.*", _ Optional strInitDir As String = vbNullString) As String On Error GoTo Proc_Error Dim OFName As OPENFILENAME Dim strFileFilter As String, strFileSelected As String strFileFilter = strFilterDescr & Chr$(0) & strFilterSpec & Chr$(0) With OFName .lStructSize = Len(OFName) .hWndOwner = 0& .hInstance = 0& 'App.hInstance 'Select a filter .lpstrFilter = strFileFilter ' "Text Files (*.txt)" & Chr$(0) &"*.txt" & Chr$(0) & "All Files (*.*)" & Chr$(0) & "*.*" & Chr$(0) .lpstrFile = Space$(254) .nMaxFile = 255 .lpstrFileTitle = Space$(254) .nMaxFileTitle = 255 If (vbNullString <> strInitDir) Then _ .lpstrInitialDir = strInitDir .lpstrTitle = strTitle ' "Select File" .flags = OFN_PATHMUSTEXIST Or OFN_FILEMUSTEXIST End With If GetOpenFileName(OFName) Then strFileSelected = Trim$(OFName.lpstrFile) If (InStr(strFileSelected, Chr(0)) > 0) Then strFileSelected = Left(strFileSelected, InStr(strFileSelected, Chr(0)) - 1) End If ShowOpen = Trim$(strFileSelected) Else ShowOpen = vbNullString End If Proc_Exit: Exit Function Proc_Error: ShowOpen = vbNullString MsgBox Err.Description Resume Proc_Exit End Function
Hi Erling,
Erling T.L. Kristensen said:In the code to this form I include a call to Function "ShowOpen":
From the posted snippet, it's not clear where GetOpenFileName method comes from.
Because you work with properties like .hWndOwner etc, it seems you call Win32 API directly?
In fact it's not MicroStation VBA question at all, but when you call native API, it's better to ask "how to do the same in 64bit environment" and I assume general VBA forums (like StackOverflow or similar) are better places where to ask.
Erling T.L. Kristensen said:Why don't this work in a newer MicroStation?
Because MicroStation V8i is 32bit application and MicroStation CE is 64bit application, all external resource used in your code have to be revisited and often modified or rewritten:
With regards,
Jan
Erling T.L. Kristensen said:I have problems using vba Function "ShowOpen". My vba runs fine on MicroStation V8i (SELCTseries 3), but it will not open Dialogbox for selecting file in a newer MicroSration version.
As Jan says, 64-bit VBA is not 32-bit VBA, and Microsoft changed things!
Read this article about the Microsoft Common Dialogs.
Thanks a lot Jan.
I also thought 64bit could be a problem. And yes I use Windows Win32 API.
Option Explicit ' --------------------------------------------------------------------- ' Win32 API declarations so that VBA can call ' Windows functions directly ' --------------------------------------------------------------------- #If VBA7 Then Private Declare PtrSafe Function GetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" (pOpenfilename As OPENFILENAME) As Long Private Declare PtrSafe Function GetSaveFileName Lib "comdlg32.dll" Alias "GetSaveFileNameA" (pOpenfilename As OPENFILENAME) As Long #Else Private Declare Function GetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" (pOpenfilename As OPENFILENAME) As Long Private Declare Function GetSaveFileName Lib "comdlg32.dll" Alias "GetSaveFileNameA" (pOpenfilename As OPENFILENAME) As Long #End If
I I thought this was sufficient, but do I need more?
