Dear Team,
We are migrating old MicroStation V8 tools(.ma) to CONNECT EDITION 14.
Our old v8 tools contains .rsc resources only but for migration we need .r files it seems.
can i migrate my old v8 tool with .rsc file or i need .r file as mandatory ?
Thanks in advance.
Dear Daniel,
Daniel Bollavarapu said:Our old v8 tools contains .rsc resources only but for migration we need .r files it seems.
Inside MicroStation v8.1 developer tools, there were key-ins as follows. You may try it to generate .r file from .rsc files. I was using this utility to generate resource file (.r) of icon resources (.rsc). As described by Jan and Jon, normal generation process of .rsc file is from .r source file.
MicroStation v8.1 Developer Tools;
MDL L ICONEDIT - Edit icons.MDL L SOURCER - Convert resource files to source code.MDL L BUILDER - Build Dialog Boxes.MDL L CMDTEDIT - Command table editorMDL L STRGEDIT - String List editorMDL L RDE - Resource Editor
Kind regards,
Sedat AlisAEC Technology Inc.
Answer Verified By: Daniel Bollavarapu
Sedat Alis said: I was using this utility to generate resource file (.r) of icon resources (.rsc)
With CONNECT, we can use Windows icons in our apps. For legacy purposes, you may need to retain icon resource definitions, but I haven't used them in new apps for many years now.
