[C++ Connect U14] Placing parametric cells takes long time
Hi
I've made some code to place parametric cells and edit the ItemType property values. I've realized that when I work with parametric cells that are just a little complex it takes quite some time.
        auto& cellHandler = ParametricCellHandler::GetInstance();
		EditElementHandle defCellEeh;
		if (ParameterStatus::Success != cellHandler.CreateCellElement(defCellEeh, *defaultInfo))
			return ERROR;
		lifalib_eehSetLvAndActiveCoWtSt(defCellEeh, levelID, false, false, false, true);
		lifalib_log("lifalib", 2, 1, "lifalib_placeParametricCellWC - Before addToModel");
		defCellEeh.AddToModel();
		lifalib_log("lifalib", 2, 1, "lifalib_placeParametricCellWC - After addToModel");
		lifalib_log("lifalib", 2, 1, "lifalib_placeParametricCellWC - Before updateItemTypes");
		std::vector<WString> params;
		std::vector<WString> values;
		if (!splitParams(strParams, strValues, params, values))
			return false;
		for (int paramIndex = 0; paramIndex < (int)params.size(); paramIndex++)
			double value;
			if (swscanf(values[paramIndex].c_str(), L"%lf", &value) == 1)
				//lifalib_updateItemTypePropertyOnElm3(defCellEeh, L"LIFA", L"Rectangle", params[paramIndex].c_str(), NULL, NULL, &value, NULL);
				lifalib_updateItemTypePropertyOnElm3(defCellEeh, L"Symboler", L"Tree", params[paramIndex].c_str(), NULL, NULL, &value, NULL);
			else
				return false;
		lifalib_log("lifalib", 2, 1, "lifalib_placeParametricCellWC - After updateItemTypes");
I've attached a cellibrary with 3 cells.
When I use this code with the cell "Rectangle" - (very simple) it goes quite fast - something between 2 and 3 seconds to place 10 cells.
When I use the cell "Tree" it takes about 11 seconds to place 10 cells. When I remove half of the elements in this cell (see "Tree2" the time is approx. halved.
How can that be ?
TIA, Evan
ParametricSymbols.cel
  • swscanf(values[paramIndex].c_str(), L"%lf", &value)
    You're writing C++  — try std::stod().
    But that function is opaque to us. It's hard for the doctor to examine a patient who is absent.
    Regards, Jon Summers
    LA Solutions
  • The function looks like this:
    BentleyStatus lifalib_updateItemTypePropertyOnElm3(EditElementHandleR eehBaseElm, const wchar_t* pchItemTypeLibName, const wchar_t* pchItemTypeName, const wchar_t* pchPropName, bool* newValueBoolP, int* newValueIntP, double* newValueDoubleP, wchar_t* newValueString)
    	CustomItemHost  itemHost(eehBaseElm, true);
    	DgnECInstancePtr hostItemData = itemHost.GetCustomItem(pchItemTypeLibName, pchItemTypeName);
    	ECValue value;
    	bool valueUpdated = false;
    	ECObjectsStatus rc = ECOBJECTS_STATUS_Error;
    	if (hostItemData != NULL)
    		if ((rc = hostItemData->GetValue(value, pchPropName)) == ECObjectsStatus::ECOBJECTS_STATUS_Success)
    			switch (value.GetPrimitiveType())
    			case PrimitiveType::PRIMITIVETYPE_Boolean:
    				value.SetBoolean(*newValueBoolP);
    				valueUpdated = true;
    				break;
    			case PrimitiveType::PRIMITIVETYPE_Integer:
    				value.SetInteger(*newValueIntP);
    				break;
    			case PrimitiveType::PRIMITIVETYPE_Double:
    				value.SetDouble(*newValueDoubleP);
    				break;
    			case PrimitiveType::PRIMITIVETYPE_String:
    				value.SetString(newValueString);
    				break;
    			default:
    				lifalib_dmsg("lifalib_updateItemTypePropertyOnElm - Unknown propertyType %d", value.GetPrimitiveType());
    				break;
    			if (valueUpdated)
    				if ((rc = hostItemData->SetValue(pchPropName, value)) == ECOBJECTS_STATUS_Success)
    					hostItemData->WriteChanges();
    	if (rc != ECOBJECTS_STATUS_Success)
    		wchar_t statusMessage[100];
    		lifalib_getECObjectsStatusMessage(rc, statusMessage);
    		lifalib_dmsg("Error by updating ItemType property %ls->%ls: %ls", pchItemTypeName, pchPropName, statusMessage);
    		return ERROR;
    	else
    		return SUCCESS;
    Regards, Evan
  • CustomItemHost  itemHost(eehBaseElm, true);
    Functions that take an enum are self-documenting because the enum member is self-describing.  Funtions that take a bool are better written with an explicit named value...
    const bool ScheduleItems { true };
    CustomItemHost  itemHost(eehBaseElm, ScheduleItems);
    That duplicates the default CustomItemHost constructor.  Furthermore, it throws light onto this later statement...
    In other words, you've instructed MicroStation to update your Item Type properties, and then you update them yourself.  Do one or the other, but not both.
    LA Solutions
  • Hi Jon,
    Thank you very much for your reply. I've changed the code, but it still takes about 11 seconds to place and update 10 parametric cells using the cell "Tree".
    Regards, Evan
  • What happens if you don't call lifalib_updateItemTypePropertyOnElm3?  That is, is your performance degraded by creating the parametric cell or by updating its values?
    LA Solutions
  • Adding the cell to the model takes approx 450 milliseconds and updating the values takes approx. 650 milliseconds for each cell...
    Regards, Evan
    I have zero experience what can be treated as "good performance", but > .5 sec to update parameters sounds like too much. The question is whether the problem is in the cell (probably not), in the constrains solver or somewhere else.
    I've made some code
    I have to say I find the naming used a bit confusing, because defCellEeh looks like "definition cell", which is not. Parametric cell definition cell is shared cell, stored in active DGN file, whether in your code defCellEeh represents newly created parametric cell instance.
    But I know, it's the code available in SDK examples...
      Jan
    So it's like a swan swimming on a lake: On the surface, all appears serene, but there's a furious amount of activity in the water.
    LA Solutions
  • Hi ,
    A couple (possibly rhetorical) thoughts that may help further clarify and identify one or more issues...
    1. Where are the design file (_DGNFILE) and user preference file (MS_USERPREF) located?
      1. Local or Network:
      2. SSD or HDD:
    2. Network data points:
      1. VPN, WAN, LAN:
      2. Average Latency (in ms) to server (ping or tracert):
    3. Performance Profiling tools - gain insights into call stack method time and iterations spent:
      1. [Recommend trying firstMicrosoft Visual Studio Performance Tools (Monitor CPU Time. Sample Video)
      2. Microsoft Debug Diagnostics Tool (debugdiag. Sample Video. Compare multiple full memory dumps for app performance issues)
      3. Microsoft Process Monitor (procmon. Time spent on Files, App Call Stacks, other application/setting insights)
      4. Microsoft, Intel, AMD, Telerik and many software vendors provide additional Free or Paid performance analysis tools that can help speed troubleshooting memory and design performance issues.
    HTH,
    Bob
