I want to get a DGN file's brand (i.e. Its workspace and workset). I've made some progress...
if (DgnWorkSetInfo.ExistsOnDgnFile(dgnFile)) { using (DgnWorkSetInfo info = DgnWorkSetInfo.ExtractFromDgnFile(dgnFile)) { string s = $"Workset name '{info.Name}'"; } }
I'd also like to get the workspace name. Unfortunately, while the MicroStationAPI has IDgnWorkSetInfoPtr->GetWorkSpaceName(), the .NET equivalent doesn't seem to exist. Have I missed something?
SDK example ../Miscellaneous/CheckWorkSetPaths shows how to do this using C++.
This code should work:
DgnWorkSet dgnWorkSet = WorkSpaceManager.ActiveWorkSet; string workSetName = dgnWorkSet.Name; string workspaceName = dgnWorkSet.WorkSpaceName;
With regards,
Jan
Thanks! How did you find WorkSpaceManager? It's not documented and it's not used in the SDK examples.
WorkSpaceManager
However, it doesn't answer the more general question: how to get a particular DGN file's workspace branding (when that file is not the active DGN file). That is, if I open a DGN file as a working file, how do I extract the branding info using .NET?
As usually, using a process I described several times already: using NET Reflectory. But any free tool like DnSpy would be probably enough too.
The discussed case was simpler than it often is, because native code equivalent is known. So it's about:
Jon Summers said:The MicroStationAPI has IDgnWorkSetInfoPtr->GetWorkSpaceName(), the .NET equivalent doesn't seem to exist. Have I missed something?
Would anyone from Bentley Systems like to comment? It looks like someone omitted a .NET wrapper around a MicroStationAPI method in the published API.
Hi Jon Summers,
I will check with development for recommendations and see if we can (finally) publish the .NET WorkspaceManager APIs.
Thank you,Bob
