A Table Seed is a model in a DGN file. Usually the DGN file is a DGNLib listed in configuration variable MS_DGNLIBLIST. To find a table seed programmatically, I suppose that the procedure looks like this...
MS_DGNLIBLIST
Here's some code...
public int GetTableSeedModels () { int nModels = 0; DgnLibIterator iterator = new DgnLibIterator(DgnLibSelector.ElementStyles); foreach (DgnFile lib in iterator) { // Examine each DGN model in the file var indices = lib.GetModelIndexCollection(); foreach (var index in indices) { StatusInt status; DgnModel model = lib.LoadRootModelById(out status, index.Id); if (IsTableSeed(model)) { string s = $"Table seed: {lib.GetFileName ()}.{model.ModelName}"; MessageCenter.Instance.ShowMessage(MessageType.Debug, s, s, MessageAlert.None); ++nModels; } } } return nModels; }
private bool IsTableSeed (DgnModel model) { ElementId dummy = DgnTextStyle.GetSettings(Session.Instance.GetActiveDgnFile()).Id; // Use static method to create a TextTable for testing TextTable someTable = TextTable.Create(1, 1, dummy, 1.0, model); // Attempt to copy the DGN model to see if it is a Table Seed TextTable table = someTable.Copy(model); return (null != table); }
That almost works. It gives me the models that contain a Table Seed, but it also gives me the default model in each DGN file when that does not contain a Table Seed. I admit that function IsTableSeed looks clunky. Is there a better way?
IsTableSeed
To be a valid seed, the model must contain only one graphical element and that element must be a table.
Yongan.Fu said:To be a valid seed, the model must contain only one graphical element and that element must be a table
I'm well aware of that. When placing a table manually, the menu offers a choice of seeds.
My question is: How do we answer that question programmatically? What is the C++ or .NET procedure to determine if a DGN model contains a Table?
Is my function IsTableSeed() implemented correctly, or can it be improved?
IsTableSeed()
Jon Summers said:How do we answer that question programmatically?
Jon Summers said:Is my function IsTableSeed() implemented correctly, or can it be improved?
Iterate all models in available dgnlib files and check if the model only contains one graphical element and this element is a TextTable element.
To verify this, I did below steps:
Then the TableSeed dropdown list only displays the copied model name. Shown as below:
Jon Summers said:What is the C++ or .NET procedure to determine if a DGN model contains a Table?
Get the only one graphical element and judge if it is a texttable element. For C++, we can use dynamic_cast<TextTableHandler *>(&eh.GetHandler()) to determine if an ElementHandle is a textTable element.
Answer Verified By: Jon Summers
Yongan.Fu said:Get the only one graphical element and judge if it is a TextTable element
Thanks! So my above approach to test whether a DGN model can be used as a TextTable Seed is incorrect?
Here a new test, implemented for .NET, that appears to work...
private bool IsTableSeed(DgnModel model) { var elements = model.GetGraphicElements(); return (elements.Count() == 1 && elements.First() is TextTableElement); }
Here's an article Table Seed Harvester that summarises the findings in this thread.
