Connect Edition/ Change Extents in Saved Views
Hello everybody,
I have problems with changing property "Extents" in such element as "Saved View".
First I create Saved View with certain Extents, using this code
Dim wPt As Point3d
wPt.x = aX
wPt.y = aY
wPt.z = aZ
ActiveDesignFile.Views(2).Extents = wPt
It works, but after I need to change one Extent ( for e[ample X)
I wrote, after creation of Saved View
OPH.SelectByAccessString ("Extents")
pPt.x = aX
pPt.y = aY
pPt.z = aZ
OPH.SetValueAsPoint3d pPt
But it doesn't work. For some reason this code works perfectly in AECOsim v8
Moreover, I cannot change Extents for Saved Views even manually in Property windiow.
Redraw - I have used, already))
Thanks in advance!
Full code for SavedView creation
With CommandState.LastView
.SetToTop
.Redraw
End With
Dim activeView As MicroStationDGN.View
Dim iViewNumber As Integer
Dim rotView As Matrix3d
Dim rotStep As Matrix3d
Dim diam As Integer
diam = aY / Cos(Atn(aX / aY))
Set activeView = CommandState.LastView
v1 = 0
rotView = activeView.rotation
rotStep = Matrix3dFromAxisAndRotationAngle(2, v1)
rotView = Matrix3dFromMatrix3dTimesMatrix3d(rotView, rotStep)
activeView.rotation = rotView
Dim qPt As Point3d
qPt.x = minkx * 1000
qPt.y = minky * 1000
qPt.z = minkz * 1000
ActiveDesignFile.Views(2).Origin = qPt
Dim wPt As Point3d
wPt.x = aX
wPt.y = aY
wPt.z = aZ
ActiveDesignFile.Views(2).ClipBack = True
ActiveDesignFile.Views(2).ClipFront = True
'ActiveDesignFile.Views(2).Redraw
Dim name_view As String
If d1 = "" Then
name_view = "_" & d & "_" & "V1"
Else: name_view = "_" & d1 & "_" & "V1"
End If
ActiveModelReference.AddElement CreateSavedViewElement(2, name_view)
Set ele = ActiveDesignFile.FindSavedView(name_view)
Set OPH = CreatePropertyHandler(ele)
pPt.x = aX
pPt.y = aY
pPt.z = aZ
OPH.SelectByAccessString ("Origin")
OPH.SetValueAsPoint3d qPt
