Take a look at the following screenshot:
This is a drawing model which contains a detail callout of the design model. I'm trying to get the callout rectangle coordinates programatically. The callout is a reference into the design model but if I retrieve the reference bounding box I get the "photo corners" rectangle rather than the callout rectangle.
Why is the reference boundary offset from the callout?
Are there more efficient methods to get the callout boundary coordinates?
Hi Benzi,
because this is MicroStation Programming forum, what is "development question"? And for what language and API?
Jan
I'm using the CONNECT API to write a native code MDL application to extract the callout real-world location and add a coordinate frame around the callout. This is part of our sheet production standard. Right now the coordinate frame is not positioned on the callout itself but rather on the "photo corners" rectangle:
