[CONNECT bmake] Resource Compiler Cannot write to output file
My C++ project that built successfully yesterday fails to build today.  Something's happened to affect rlib.exe. There was an automatic Windows update between good results and bad results.
I opened instead the Basic Dialog Box example, which remains as delivered by the SDK.  Most of the build succeeds.  It's the last part, where rlib is merging resources into the .ma file, that fails...
[== Building G:\PROGRA~1\Bentley\MICROS~2\MICROS~1\mdlapps\basic.ma, (G:\PROGRA~1\Bentley\MICROS~2\SDK\reqdobjs\basic.mi) ==]
rlib @G:\PROGRA~1\Bentley\MICROS~2\SDK\rscobj\make.opt
### Error: File=(G:\PROGRA~1\Bentley\MICROS~2\SDK\reqdobjs\basic.mi),
		 Type=('MDLn'), RscId=(1), status = (-902)
... many more similar lines
### Error: File=(G:\PROGRA~1\Bentley\MICROS~2\SDK\rscobj\basicmsg.rsc),
		 Type=('dDef'), RscId=('str#'), status = (-902)
### Cannot write to output file: G:\PROGRA~1\Bentley\MICROS~2\MICROS~1\mdlapps\basic.ma
### Data was saved to a file called: G:\PROGRA~1\Bentley\MICROS~2\MICROS~1\mdlapps\basic.tmp
What is rlib error -902?  It says it cannot write to basic.ma, but I'm doing nothing with that file — MicroStation is not open.  It also tells me that it saved to basic.tmp instead — but that file doesn't exist.
Here's the log of the build:
Bentley Systems Make Utility. Version 10.00.00.26, Mar 15 2018
Sun Oct 18 14:47:05 2020
D:\temp\getucrtversion2017.bat
[== Building G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basiccmd.h, (G:\PROGRA~1\Bentley\MICROS~2\SDK\examples\DialogBoxes\BasicDialogBox\basiccmd.r) ==]
rcomp @G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\make.opt
MicroStation Resource Compiler 03.19.02
   Generating header file (G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basiccmd.h) ... done.
[== Building G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basiccmd.rsc, (G:\PROGRA~1\Bentley\MICROS~2\SDK\examples\DialogBoxes\BasicDialogBox\basiccmd.r) ==]
[== Building G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basictyp.r, (G:\PROGRA~1\Bentley\MICROS~2\SDK\examples\DialogBoxes\BasicDialogBox\basictyp.mt) ==]
rsctype @G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\make.opt
MicroStation Type Resource File Generator 03.19.02
[== Building G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basictyp.rsc, (G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basictyp.r) ==]
[== Building G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basic.obj, (G:\PROGRA~1\Bentley\MICROS~2\SDK\examples\DialogBoxes\BasicDialogBox\basic.cpp) ==]
cl -IG:\PROGRA~1\Bentley\MICROS~2\SDK\include\ -IG:\PROGRA~1\Bentley\MICROS~2\SDK\mki\    -fp:precise -GS- -EHc -GR -wd4345 -GF -favor:blend -D_X64_ -wd4701 -wd4244 -wd4564 -wd4840 -wd4702 -c -W4 -DBENTLEY_WARNINGS_HIGHEST_LEVEL -DWIN32 -DwinNT -MD -D__EXCEPTIONS -D_VISCXX -Gy -wd4996 -Ox -Oy- -Os -D_CONVERSION_DONT_USE_THREAD_LOCALE -D_SECURE_SCL=0 -DWIN32_LEAN_AND_MEAN  -DNTDDI_WIN7SP1=0x06010100 -we4692  -nologo -WX -MP -Zi -Zo -FdG:\PROGRA~1\Bentley\MICROS~2\SDK\objects\objects.pdb    -EHs   -fp:precise -FoG:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basic.obj G:\PROGRA~1\Bentley\MICROS~2\SDK\examples\DialogBoxes\BasicDialogBox\basic.cpp
basic.cpp
[== Building "G:\PROGRA~1\Bentley\MICROS~2\MICROS~1\mdlapps\basic.dll", (G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basic.obj) ==]
link -out:"G:\PROGRA~1\Bentley\MICROS~2\MICROS~1\mdlapps\basic.dll"  -WX   -Ignore:4087 -Ignore:4089 -Ignore:4199 -Ignore:4281 -MANIFESTUAC:NO -Release   -debug -incremental:no -fixed:no @G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basiclink.rsp
Microsoft (R) Incremental Linker Version 14.16.27038.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-dynamicbase
-dll
"-out:G:\PROGRA~1\Bentley\MICROS~2\MICROS~1\mdlapps\basic.dll"
"-implib:G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basic.lib"
"-pdb:G:\PROGRA~1\Bentley\MICROS~2\MICROS~1\mdlapps\basic.pdb"
-fixed:no
G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basic.obj G:\PROGRA~1\Bentley\MICROS~2\SDK\library\BentleyAllocator.lib gdi32.lib user32.lib kernel32.lib "G:\PROGRA~2\VI44E1~1\VC\Tools\MSVC\14.16.27023\lib\x64\msvcrt.lib"
G:\PROGRA~1\Bentley\MICROS~2\SDK\library\mdlbltin.lib
   Creating library G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basic.lib and object G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basic.exp
[== Building G:\PROGRA~1\Bentley\MICROS~2\SDK\reqdobjs\basic.mi, (G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\basiccmd.rsc) ==]
rlib @G:\PROGRA~1\Bentley\MICROS~2\SDK\objects\make.opt
MicroStation Resource Librarian 03.19.02
[== Building G:\PROGRA~1\Bentley\MICROS~2\SDK\rscobj\basic.rsc, (G:\PROGRA~1\Bentley\MICROS~2\SDK\examples\DialogBoxes\BasicDialogBox\basic.r) ==]
[== Building G:\PROGRA~1\Bentley\MICROS~2\SDK\rscobj\basicmsg.rsc, (G:\PROGRA~1\Bentley\MICROS~2\SDK\examples\DialogBoxes\BasicDialogBox\transkit\basicmsg.r) ==]
		 Type=('CmdT'), RscId=(1), status = (-902)
		 Type=('CEna'), RscId=(0), status = (-902)
		 Type=('CEna'), RscId=(1), status = (-902)
		 Type=('CEna'), RscId=(2), status = (-902)
		 Type=('CEst'), RscId=(1), status = (-902)
		 Type=('CEty'), RscId=(0), status = (-902)
		 Type=('CEty'), RscId=(1), status = (-902)
		 Type=('CEme'), RscId=(0), status = (-902)
		 Type=('dDef'), RscId=('CEme'), status = (-902)
		 Type=('dDef'), RscId=('CEna'), status = (-902)
		 Type=('dDef'), RscId=('CEst'), status = (-902)
		 Type=('dDef'), RscId=('CEty'), status = (-902)
		 Type=('dDef'), RscId=('CmdT'), status = (-902)
		 Type=('dDef'), RscId=('MDLn'), status = (-902)
### Error: File=(G:\PROGRA~1\Bentley\MICROS~2\SDK\rscobj\basic.rsc),
		 Type=('dBox'), RscId=(1), status = (-902)
		 Type=('dBox'), RscId=(2), status = (-902)
		 Type=('dTxt'), RscId=(1), status = (-902)
		 Type=('oBtn'), RscId=(1), status = (-902)
		 Type=('pBtn'), RscId=(1), status = (-902)
		 Type=('tBtn'), RscId=(1), status = (-902)
		 Type=('syns'), RscId=(1), status = (-902)
		 Type=('dDef'), RscId=('dBox'), status = (-902)
		 Type=('dDef'), RscId=('dTxt'), status = (-902)
		 Type=('dDef'), RscId=('oBtn'), status = (-902)
		 Type=('dDef'), RscId=('pBtn'), status = (-902)
		 Type=('dDef'), RscId=('syns'), status = (-902)
		 Type=('dDef'), RscId=('tBtn'), status = (-902)
		 Type=('str#'), RscId=(1), status = (-902)
Sun Oct 18 14:47:16 2020, elapsed time: 0:11
BMAKE: file [G:\PROGRA~1\Bentley\MICROS~2\MICROS~1\mdlapps\basic.ma] may be incomplete
BMAKE: call trace
    line:  102, G:\Program Files\Bentley\MicroStation CONNECT Edition\SDK\examples\DialogBoxes\BasicDialogBox\BasicDialogBox.mke
Tool completed with exit code 1
