I developed an AddIn using the .NET API delivered with MicroStation CONNECT Update 14.2. The AddIn works fine on my computer.
When customer attempts to load the AddIn using MicroStation CONNECT Update 10, it fails. The full error dump is attached, but the first few lines tell me that Bentley.Internal.MstnPlatformNET.DotNetShim.LauncherDotNetShim.Launcher.LoadMdlProgram is the culprit.
Can anyone throw light on this? That Launcher error looks like internal MicroStation stuff that I can't fix. What .NET differences are there between Update 10 and Update 14 — are those differences responsible for this problem?
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information. at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module) at System.Reflection.Assembly.GetTypes() at Bentley.Internal.MstnPlatformNET.DotNetShim.Launcher.GetAddInTypeThroughReflection(Int32* statusCodeP, String* taskIDOverridePP, String assemblyRootName, String taskId) at Bentley.Internal.MstnPlatformNET.DotNetShim.Launcher.LoadMdlProgram(IntPtr statusCodeP, String mdlAppNameParam, String taskID, IntPtr forkFunc, IntPtr forkParams) ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll ---------------------------------------- MicroStation Assembly Version: 0.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/MicroStation.exe ---------------------------------------- Bentley.PowerPlatform.FeatureAspects Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.PowerPlatform.FeatureAspects.DLL ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- ustation Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/ustation.DLL ---------------------------------------- Bentley.General.1.0 Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.General.1.0.DLL ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Bentley.DgnPlatformNET Assembly Version: 1.0.0.0 Win32 Version: 02.15.02.27 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.DgnPlatformNET.DLL ---------------------------------------- Bentley.MicroStation.Interfaces.1.0 Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.Interfaces.1.0.DLL ---------------------------------------- Microsoft.ApplicationBlocks.ExceptionManagement.1.0 Assembly Version: 1.0.0.0 Win32 Version: 01.00.00.01 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Microsoft.ApplicationBlocks.ExceptionManagement.1.0.DLL ---------------------------------------- Bentley.ECObjects3 Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.ECObjects3.DLL ---------------------------------------- Bentley.Platform Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.Platform.DLL ---------------------------------------- Bentley.GeometryNET.Common Assembly Version: 1.0.0.0 Win32 Version: 02.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.GeometryNET.Common.DLL ---------------------------------------- Bentley.GeometryNET.Structs Assembly Version: 1.0.0.0 Win32 Version: 02.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.GeometryNET.Structs.DLL ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- Bentley.Exceptions Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.Exceptions.DLL ---------------------------------------- Bentley.logging-2.0 Assembly Version: 2.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.logging-2.0.DLL ---------------------------------------- Bentley.UI.Vendor.Wpf Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.UI.Vendor.Wpf.DLL ---------------------------------------- PresentationFramework Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll ---------------------------------------- WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- PresentationCore Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll ---------------------------------------- System.Xaml Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- Bentley.UI Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.UI.DLL ---------------------------------------- Telerik.Windows.Controls Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.DLL ---------------------------------------- Telerik.Windows.Themes.VisualStudio2013 Assembly Version: 2017.2.1717.40 Win32 Version: 2017.2.1717.40 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Themes.VisualStudio2013.DLL ---------------------------------------- Telerik.Windows.Controls.Input Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Input.DLL ---------------------------------------- Telerik.Windows.Controls.Navigation Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Navigation.DLL ---------------------------------------- Telerik.Windows.Data Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Data.DLL ---------------------------------------- Telerik.Windows.Controls.Chart Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Chart.DLL ---------------------------------------- Telerik.Windows.Controls.Data Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Data.DLL ---------------------------------------- Telerik.Windows.Controls.Docking Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Docking.DLL ---------------------------------------- Telerik.Windows.Controls.Expressions Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Expressions.DLL ---------------------------------------- Telerik.Windows.Controls.FixedDocumentViewers Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.FixedDocumentViewers.DLL ---------------------------------------- Telerik.Windows.Controls.GridView Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.GridView.DLL ---------------------------------------- Telerik.Windows.Controls.ImageEditor Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.ImageEditor.DLL ---------------------------------------- Telerik.Windows.Themes.Office2013 Assembly Version: 2017.2.1717.40 Win32 Version: 2017.2.1717.40 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Themes.Office2013.DLL ---------------------------------------- Telerik.Windows.Controls.RibbonView Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.RibbonView.DLL ---------------------------------------- Telerik.Windows.Controls.RichTextBoxUI Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.RichTextBoxUI.DLL ---------------------------------------- Telerik.Windows.Documents Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Documents.DLL ---------------------------------------- Telerik.Windows.Controls.ScheduleView Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.ScheduleView.DLL ---------------------------------------- Telerik.Windows.Controls.Diagrams Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Diagrams.DLL ---------------------------------------- Telerik.Windows.Diagrams.Core Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Diagrams.Core.DLL ---------------------------------------- Telerik.Windows.Controls.Diagrams.Extensions Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Diagrams.Extensions.DLL ---------------------------------------- Telerik.Windows.Documents.Core Assembly Version: 2017.2.1717.40 Win32 Version: 2017.2.1717.40 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Documents.Core.DLL ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- Bentley.RibbonView Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.RibbonView.DLL ---------------------------------------- Bentley.MicroStation.Ribbon Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.Ribbon.DLL ---------------------------------------- Bentley.Connect.Client.API Assembly Version: 1.0.0.0 Win32 Version: 10.00.10.19 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.Connect.Client.API.DLL ---------------------------------------- Bentley.MicroStation Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.DLL ---------------------------------------- Bentley.MicroStation.WPF Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.WPF.DLL ---------------------------------------- MdlSeed Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/MdlSeed.DLL ---------------------------------------- Bentley.TableUI Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.TableUI.DLL ---------------------------------------- Bentley.Visualization.RenderRibbonToolbar Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.Visualization.RenderRibbonToolbar.DLL ---------------------------------------- Bentley.Visualization.LightsRibbonToolbar Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.Visualization.LightsRibbonToolbar.DLL ---------------------------------------- Bentley.Visualization.MaterialsRibbonToolbar Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.Visualization.MaterialsRibbonToolbar.DLL ---------------------------------------- Bentley.DrawingScale Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.DrawingScale.DLL ---------------------------------------- Bentley.ViewGroupList Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.ViewGroupList.DLL ---------------------------------------- Bentley.ViewGroupHistory Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.ViewGroupHistory.DLL ---------------------------------------- Bentley.Macros.UI Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/Bentley.Macros.UI.DLL ---------------------------------------- Bentley.Macros Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/Bentley.Macros.DLL ---------------------------------------- System.Windows.Interactivity Assembly Version: 4.0.0.0 Win32 Version: 2.0.20520.0 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/System.Windows.Interactivity.DLL ---------------------------------------- PresentationFramework-SystemXml Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll ---------------------------------------- Bentley.DialogManager Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.DialogManager.DLL ---------------------------------------- Bentley.MicroStation.MiniToolbar Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.MiniToolbar.DLL ---------------------------------------- PresentationFramework.Aero2 Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll ---------------------------------------- Bentley.Connect.Client.Service.Interface Assembly Version: 1.0.0.0 Win32 Version: 10.00.10.19 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.Connect.Client.Service.Interface.DLL ---------------------------------------- Bentley.Select.Shareable Assembly Version: 1.0.0.0 Win32 Version: 10.00.10.19 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.Select.Shareable.DLL ---------------------------------------- System.ComponentModel.Composition Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.Composition/v4.0_4.0.0.0__b77a5c561934e089/System.ComponentModel.Composition.dll ---------------------------------------- Common.Logging Assembly Version: 3.3.1.0 Win32 Version: 3.3.1.0 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Common.Logging.DLL ---------------------------------------- Common.Logging.Core Assembly Version: 3.3.1.0 Win32 Version: 3.3.1.0 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Common.Logging.Core.DLL ---------------------------------------- MetadataViewProxies_ba13167d-2d34-4cc7-bc69-a6abba84b33f Assembly Version: 0.0.0.0 Win32 Version: 4.8.3761.0 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.Composition/v4.0_4.0.0.0__b77a5c561934e089/System.ComponentModel.Composition.dll ---------------------------------------- System.Runtime.Serialization Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll ---------------------------------------- System.ServiceModel Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll ---------------------------------------- SMDiagnostics Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll ---------------------------------------- System.ServiceModel.Internals Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll ---------------------------------------- Bentley.StartScreen Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.StartScreen.DLL ---------------------------------------- Bentley.Recommendation.API1 Assembly Version: 1.0.0.0 Win32 Version: 10.00.10.19 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.Recommendation.API1.DLL ---------------------------------------- UIAutomationTypes Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll ---------------------------------------- UIAutomationProvider Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll ---------------------------------------- MarkupAddIn Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/required/MarkupAddIn.DLL ---------------------------------------- Bentley.DgnDisplayNET Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.DgnDisplayNET.DLL ---------------------------------------- Bentley.iModelAttach Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.iModelAttach.DLL ---------------------------------------- Bentley.MicroStation.Templates Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.Templates.DLL ---------------------------------------- Bentley.MicroStation.Templates.Support Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.Templates.Support.DLL ---------------------------------------- Bentley.MicroStation.WinForms.ECPropertyPane Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.WinForms.ECPropertyPane.DLL ---------------------------------------- Bentley.MicroStation.WinForms.Controls Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.WinForms.Controls.DLL ---------------------------------------- Bentley.MicroStation.MaterialControl Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.MaterialControl.DLL ---------------------------------------- Bentley.TerrainModel.ElementTemplate Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.TerrainModel.ElementTemplate.DLL ---------------------------------------- TerrainModelHandlerApp Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/TerrainModelHandlerApp.DLL ---------------------------------------- Bentley.ExpressionEvaluator Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.ExpressionEvaluator.DLL ---------------------------------------- Bentley.TerrainModelNET.Element Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/Bentley.TerrainModelNET.Element.DLL ---------------------------------------- Bentley.ECSystem3 Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.ECSystem3.DLL ---------------------------------------- Bentley.EC.AbstractUI3 Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.EC.AbstractUI3.DLL ---------------------------------------- Bentley.RSS Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.RSS.DLL ---------------------------------------- Bentley.RSS.Interop Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.RSS.Interop.DLL ---------------------------------------- Bentley.MicroStation.PWCatalog Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.PWCatalog.DLL ---------------------------------------- Bentley.CatalogService.Api.Interfaces Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.27 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.CatalogService.Api.Interfaces.DLL ---------------------------------------- Bentley.CatalogService.PublishingDialog Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.27 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.CatalogService.PublishingDialog.DLL ---------------------------------------- Bentley.Visualization.TypeEditors Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/Bentley.Visualization.TypeEditors.DLL ---------------------------------------- CivilEH Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/CivilEH.DLL ---------------------------------------- Bentley.DesignlinksApp Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/Bentley.DesignLinksApp.DLL ---------------------------------------- Bentley.EC.Controls3 Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.EC.Controls3.DLL ---------------------------------------- Bentley.ExtensionDiscovery Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.ExtensionDiscovery.DLL ---------------------------------------- Bentley.EC.Persistence3 Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/BENTLEY.EC.PERSISTENCE3.DLL ---------------------------------------- System.Data Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll ---------------------------------------- Bentley.EC.Presentation3 Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/BENTLEY.EC.PRESENTATION3.DLL ---------------------------------------- Bentley.MicroStation.ECIntegration Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/BENTLEY.MICROSTATION.ECINTEGRATION.DLL ---------------------------------------- Bentley.RuleDrivenPresentationECPlugin Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/extensions/Bentley.RuleDrivenPresentationECPlugin.DLL ---------------------------------------- Bentley.RuleDrivenPresentationECPlugin.PresentationRules Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/extensions/Bentley.RuleDrivenPresentationECPlugin.PresentationRules.DLL ---------------------------------------- Bentley.DgnECPlugin3 Assembly Version: 1.0.0.0 Win32 Version: 04.15.02.27 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/extensions/Bentley.DgnECPlugin3.DLL ---------------------------------------- CifDWGExportManager Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/CifDWGExportManager.DLL ---------------------------------------- Bentley.StatusCursorPrompt Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/Bentley.StatusCursorPrompt.DLL ---------------------------------------- Bentley.MicroStation.CursorPrompt Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.CursorPrompt.DLL ---------------------------------------- DgnDisplayUI2 Assembly Version: 1.0.0.0 Win32 Version: 03.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/DgnDisplayUI2.DLL ---------------------------------------- Bentley.MessageCenter Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/required/Bentley.MessageCenter.DLL ---------------------------------------- Bentley.ECObjects.MixedMode3 Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.ECObjects.MixedMode3.DLL ---------------------------------------- Bentley.PropertyManager Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.PropertyManager.DLL ---------------------------------------- Bentley.Windowing Assembly Version: 1.0.0.0 Win32 Version: 09.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.Windowing.DLL ---------------------------------------- Bentley.MicroStation.WinForms.Docking Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.WinForms.Docking.DLL ---------------------------------------- DgnDisplayCSUI2 Assembly Version: 1.0.0.0 Win32 Version: 03.15.02.28 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/DgnDisplayCSUI2.DLL ---------------------------------------- Anonymously Hosted DynamicMethods Assembly Assembly Version: 0.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll ---------------------------------------- PresentationFramework-SystemData Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll ---------------------------------------- System.Numerics Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll ---------------------------------------- Bentley.Interop.MicroStationDGN Assembly Version: 8.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.Interop.MicroStationDGN.DLL ---------------------------------------- Bentley.CatalogService.CatalogExplorer Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.27 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.CatalogService.CatalogExplorer.DLL ---------------------------------------- Bentley.CatalogService.Api Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.27 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.CatalogService.Api.DLL ---------------------------------------- Bentley.RSS.Common Assembly Version: 1.0.0.0 Win32 Version: 10.10.00.23 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.RSS.Common.DLL ---------------------------------------- Ali.MicroStation2020 Assembly Version: 20.10.13.0 Win32 Version: 10.0.14.2 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlapps/ALi.MicroStation2020.DLL ---------------------------------------- System.Net.Http Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll ---------------------------------------- Microsoft.ApplicationBlocks.ExceptionManagement.Interfaces.1.0 Assembly Version: 1.0.0.0 Win32 Version: 01.00.00.02 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Microsoft.ApplicationBlocks.ExceptionManagement.Interfaces.1.0.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Hi Jon,
Jon Summers said:The full error dump is attached
Unfortunately not :-(
Jan
Jan Ĺ legr said:Unfortunately...
Your fingers are too fast — I hadn't finished typing!
Jon Summers said:The full error dump is attached, but the first few lines tell me that Bentley.Internal.MstnPlatformNET.DotNetShim.LauncherDotNetShim.Launcher.LoadMdlProgram is the culprit.
It's not so important information in my opinion. It's only the place where the exception was thrown.
More important in my opinion is the information:
Unfortunately LoaderException property content is not included in the attached list, so it cannot be analyzed what type was not found (or found, but cannot be loaded by reflection).
To obtain more detail information, NET memory dump, or to debug the application, so how LoadMdlProgram is called can be analyzed including parameters values, is probably required.
Jon Summers said:When customer attempts to load the AddIn using MicroStation CONNECT Update 10, it fails.
Well, backward compatibility is not promised, so it probably can happen. One thing is NET Framework version, which I guess is the same 4.6.2 both for Update 10 and Update 14.2, but another is MicroStation NET API and internal code how addin is loaded, which can be different (evolving) between versions.
Jon Summers said:Can anyone throw light on this?
I do not know your code, linked assemblies and of course, also a detail list of API differences between MicroStation versions is not available, so it's a guess only:
Probably how MicroStation addin is defined (Addin class) or the way how addin is loaded to MicroStation application domain using reflection, changed between versions, so the reflection does not understand addin type (or maybe a type of some other class in your application, or maybe in MicroStation NET API itself).
I think the right approach is to compile application using the lowest supported version, expecting "it should" work with newer versions. But it's not ensured, so I guess, the only really safe way is to support e.g. NET 4.6.2 only, and to prepare individual versions for every MicroStation based on this Framework.
With regards,
Customer moved to a PC having MicroStation CONNECT Update 13 with a similar result.
************** Exception Text ************** System.Reflection.ReflectionTypeLoadException: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information. at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module) at System.Reflection.Assembly.GetTypes() at Bentley.Internal.MstnPlatformNET.DotNetShim.Launcher.GetAddInTypeThroughReflection(Int32* statusCodeP, String* taskIDOverridePP, String assemblyRootName, String taskId) at Bentley.Internal.MstnPlatformNET.DotNetShim.Launcher.LoadMdlProgram(IntPtr statusCodeP, String mdlAppNameParam, String taskID, IntPtr forkFunc, IntPtr forkParams) ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll ---------------------------------------- MicroStation Assembly Version: 0.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/microstation.exe ---------------------------------------- Bentley.PowerPlatform.FeatureAspects Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.PowerPlatform.FeatureAspects.DLL ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- ustation Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/ustation.DLL ---------------------------------------- Bentley.General.1.0 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.General.1.0.DLL ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Bentley.DgnPlatformNET Assembly Version: 1.0.0.0 Win32 Version: 02.18.02.49 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.DgnPlatformNET.DLL ---------------------------------------- Bentley.MicroStation.Interfaces.1.0 Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.Interfaces.1.0.DLL ---------------------------------------- Microsoft.ApplicationBlocks.ExceptionManagement.1.0 Assembly Version: 1.0.0.0 Win32 Version: 01.00.00.01 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Microsoft.ApplicationBlocks.ExceptionManagement.1.0.DLL ---------------------------------------- Bentley.ECObjects3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.ECObjects3.DLL ---------------------------------------- Bentley.Platform Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.Platform.DLL ---------------------------------------- Bentley.GeometryNET.Common Assembly Version: 1.0.0.0 Win32 Version: 02.18.02.44 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.GeometryNET.Common.DLL ---------------------------------------- Bentley.GeometryNET.Structs Assembly Version: 1.0.0.0 Win32 Version: 02.18.02.44 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.GeometryNET.Structs.DLL ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- Bentley.Exceptions Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.Exceptions.DLL ---------------------------------------- Bentley.logging-2.0 Assembly Version: 2.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.logging-2.0.DLL ---------------------------------------- Bentley.Licensing.Client.API Assembly Version: 1.0.0.0 Win32 Version: 11.00.10.09 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicService/Bentley.Licensing.Client.API.dll ---------------------------------------- Bentley.Licensing.ServiceInterface Assembly Version: 1.0.0.0 Win32 Version: 11.00.10.09 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECTION%20Client/LicService/Bentley.Licensing.ServiceInterface.DLL ---------------------------------------- System.ServiceModel Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll ---------------------------------------- System.Runtime.Serialization Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll ---------------------------------------- SMDiagnostics Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.ServiceModel.Internals Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll ---------------------------------------- Bentley.UI.Vendor.Wpf Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.UI.Vendor.Wpf.DLL ---------------------------------------- PresentationFramework Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll ---------------------------------------- WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- PresentationCore Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll ---------------------------------------- System.Xaml Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll ---------------------------------------- Bentley.UI Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.UI.DLL ---------------------------------------- Telerik.Windows.Controls Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.DLL ---------------------------------------- Telerik.Windows.Themes.VisualStudio2013 Assembly Version: 2017.2.1717.40 Win32 Version: 2017.2.1717.40 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Themes.VisualStudio2013.DLL ---------------------------------------- Telerik.Windows.Controls.Input Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Input.DLL ---------------------------------------- Telerik.Windows.Controls.Navigation Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Navigation.DLL ---------------------------------------- Telerik.Windows.Data Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Data.DLL ---------------------------------------- Telerik.Windows.Controls.Chart Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Chart.DLL ---------------------------------------- Telerik.Windows.Controls.Data Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Data.DLL ---------------------------------------- Telerik.Windows.Controls.Docking Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Docking.DLL ---------------------------------------- Telerik.Windows.Controls.Expressions Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Expressions.DLL ---------------------------------------- Telerik.Windows.Controls.FixedDocumentViewers Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.FixedDocumentViewers.DLL ---------------------------------------- Telerik.Windows.Controls.GridView Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.GridView.DLL ---------------------------------------- Telerik.Windows.Controls.ImageEditor Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.ImageEditor.DLL ---------------------------------------- Telerik.Windows.Themes.Office2013 Assembly Version: 2017.2.1717.40 Win32 Version: 2017.2.1717.40 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Themes.Office2013.DLL ---------------------------------------- Telerik.Windows.Controls.RibbonView Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.RibbonView.DLL ---------------------------------------- Telerik.Windows.Controls.RichTextBoxUI Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.RichTextBoxUI.DLL ---------------------------------------- Telerik.Windows.Documents Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Documents.DLL ---------------------------------------- Telerik.Windows.Controls.ScheduleView Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.ScheduleView.DLL ---------------------------------------- Telerik.Windows.Controls.Diagrams Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Diagrams.DLL ---------------------------------------- Telerik.Windows.Diagrams.Core Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Diagrams.Core.DLL ---------------------------------------- Telerik.Windows.Controls.Diagrams.Extensions Assembly Version: 2017.2.1717.45 Win32 Version: 2017.2.1717.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Controls.Diagrams.Extensions.DLL ---------------------------------------- Telerik.Windows.Documents.Core Assembly Version: 2017.2.1717.40 Win32 Version: 2017.2.1717.40 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/Telerik.Windows.Documents.Core.DLL ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- Bentley.RibbonView Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.RibbonView.DLL ---------------------------------------- Bentley.MicroStation.Ribbon Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.Ribbon.DLL ---------------------------------------- Bentley.MicroStation Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.DLL ---------------------------------------- Bentley.MicroStation.WPF Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.WPF.DLL ---------------------------------------- MdlSeed Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/MdlSeed.DLL ---------------------------------------- Bentley.TableUI Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.TableUI.DLL ---------------------------------------- Bentley.DrawingScale Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.DrawingScale.DLL ---------------------------------------- Bentley.ViewGroupList Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.ViewGroupList.DLL ---------------------------------------- Bentley.ViewGroupHistory Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.ViewGroupHistory.DLL ---------------------------------------- Bentley.Macros.UI Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/Bentley.Macros.UI.DLL ---------------------------------------- Bentley.Macros Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/Bentley.Macros.DLL ---------------------------------------- System.Windows.Interactivity Assembly Version: 4.0.0.0 Win32 Version: 2.0.20520.0 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Telerik/System.Windows.Interactivity.DLL ---------------------------------------- PresentationFramework-SystemXml Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll ---------------------------------------- Bentley.DialogManager Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.DialogManager.DLL ---------------------------------------- Bentley.MicroStation.MiniToolbar Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.MiniToolbar.DLL ---------------------------------------- PresentationFramework.Aero2 Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll ---------------------------------------- Bentley.Connect.Client.API Assembly Version: 1.0.0.0 Win32 Version: 10.00.15.12 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.Connect.Client.API.DLL ---------------------------------------- Bentley.Connect.Client.Service.Interface Assembly Version: 1.0.0.0 Win32 Version: 10.00.15.12 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.Connect.Client.Service.Interface.DLL ---------------------------------------- Bentley.StartScreen Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.StartScreen.DLL ---------------------------------------- Bentley.Recommendation.API1 Assembly Version: 1.0.0.0 Win32 Version: 10.00.15.12 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.Recommendation.API1.DLL ---------------------------------------- WindowsFormsIntegration Assembly Version: 4.0.0.0 Win32 Version: 4.8.4150.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll ---------------------------------------- UIAutomationTypes Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll ---------------------------------------- UIAutomationProvider Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll ---------------------------------------- MarkupAddIn Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/required/MarkupAddIn.DLL ---------------------------------------- Bentley.DgnDisplayNET Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Bentley.DgnDisplayNET.DLL ---------------------------------------- Bentley.iModelAttach Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.iModelAttach.DLL ---------------------------------------- Bentley.Windowing Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.Windowing.DLL ---------------------------------------- DgnDisplayUI2 Assembly Version: 1.0.0.0 Win32 Version: 03.18.02.50 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/DgnDisplayUI2.DLL ---------------------------------------- Bentley.MessageCenter Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/required/Bentley.MessageCenter.DLL ---------------------------------------- Bentley.MicroStation.Templates Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.Templates.DLL ---------------------------------------- Bentley.MicroStation.Templates.Support Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.Templates.Support.DLL ---------------------------------------- Bentley.MicroStation.WinForms.ECPropertyPane Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.WinForms.ECPropertyPane.DLL ---------------------------------------- Bentley.MicroStation.WinForms.Controls Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.WinForms.Controls.DLL ---------------------------------------- Bentley.MicroStation.MaterialControl Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.MaterialControl.DLL ---------------------------------------- Bentley.TerrainModel.ElementTemplate Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.TerrainModel.ElementTemplate.DLL ---------------------------------------- TerrainModelHandlerApp Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/TerrainModelHandlerApp.DLL ---------------------------------------- Bentley.ExpressionEvaluator Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.ExpressionEvaluator.DLL ---------------------------------------- Bentley.TerrainModelNET.Element Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/Bentley.TerrainModelNET.Element.DLL ---------------------------------------- Bentley.ECSystem3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.ECSystem3.DLL ---------------------------------------- Bentley.EC.AbstractUI3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.EC.AbstractUI3.DLL ---------------------------------------- Bentley.RSS Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.RSS.DLL ---------------------------------------- Bentley.RSS.Interop Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.RSS.Interop.DLL ---------------------------------------- Bentley.MicroStation.PWCatalog Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.PWCatalog.DLL ---------------------------------------- Bentley.CatalogService.PublishingDialog Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.CatalogService.PublishingDialog.DLL ---------------------------------------- Bentley.ComponentsCenter.ClientApi Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.ComponentsCenter.ClientApi.DLL ---------------------------------------- Bentley.CatalogService.CatalogExplorer Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.45 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.CatalogService.CatalogExplorer.DLL ---------------------------------------- ConnectAdvisor Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/required/ConnectAdvisor.DLL ---------------------------------------- Bentley.Connect.Advisor.Api Assembly Version: 1.0.0.0 Win32 Version: 10.01.00.135 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/ConnectAdvisor/Bentley.Connect.Advisor.Api.DLL ---------------------------------------- Bentley.Connect.Advisor.ApiFactory Assembly Version: 1.0.0.0 Win32 Version: 10.01.00.270 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.ApiFactory.dll ---------------------------------------- Bentley.Connect.Advisor.Logging Assembly Version: 1.0.0.0 Win32 Version: 10.01.00.270 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.Logging.DLL ---------------------------------------- log4net Assembly Version: 1.2.15.0 Win32 Version: 1.2.15.0 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/log4net.DLL ---------------------------------------- CivilEH Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/CivilEH.DLL ---------------------------------------- Bentley.DesignlinksApp Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/Bentley.DesignLinksApp.DLL ---------------------------------------- Bentley.Connect.Advisor.OopWrapper Assembly Version: 1.0.0.0 Win32 Version: 10.01.00.270 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.OopWrapper.dll ---------------------------------------- Bentley.Connect.Advisor.Api2 Assembly Version: 1.0.0.0 Win32 Version: 10.01.00.270 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.Api2.DLL ---------------------------------------- Bentley.Connect.Advisor.ServiceContract Assembly Version: 1.0.0.0 Win32 Version: 10.01.00.270 CodeBase: file:///C:/Program%20Files/Common%20Files/Bentley%20Shared/CONNECT%20Advisor/Bentley.Connect.Advisor.ServiceContract.DLL ---------------------------------------- Bentley.EC.Controls3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.EC.Controls3.DLL ---------------------------------------- Bentley.ExtensionDiscovery Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.ExtensionDiscovery.DLL ---------------------------------------- Bentley.EC.Persistence3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/BENTLEY.EC.PERSISTENCE3.DLL ---------------------------------------- System.Data Assembly Version: 4.0.0.0 Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll ---------------------------------------- Bentley.EC.Presentation3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/BENTLEY.EC.PRESENTATION3.DLL ---------------------------------------- Bentley.MicroStation.ECIntegration Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/BENTLEY.MICROSTATION.ECINTEGRATION.DLL ---------------------------------------- Bentley.RuleDrivenPresentationECPlugin Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/extensions/Bentley.RuleDrivenPresentationECPlugin.DLL ---------------------------------------- Bentley.RuleDrivenPresentationECPlugin.PresentationRules Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/extensions/Bentley.RuleDrivenPresentationECPlugin.PresentationRules.DLL ---------------------------------------- Bentley.DgnECPlugin3 Assembly Version: 1.0.0.0 Win32 Version: 04.18.02.49 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/extensions/Bentley.DgnECPlugin3.DLL ---------------------------------------- CifDWGExportManager Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/CifDWGExportManager.DLL ---------------------------------------- Bentley.StatusCursorPrompt Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlsys/asneeded/Bentley.StatusCursorPrompt.DLL ---------------------------------------- Bentley.MicroStation.CursorPrompt Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.CursorPrompt.DLL ---------------------------------------- Bentley.ECObjects.MixedMode3 Assembly Version: 1.0.0.0 Win32 Version: 09.18.02.43 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/ECFramework/Bentley.ECObjects.MixedMode3.DLL ---------------------------------------- Bentley.PropertyManager Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.PropertyManager.DLL ---------------------------------------- Bentley.MicroStation.WinForms.Docking Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.MicroStation.WinForms.Docking.DLL ---------------------------------------- DgnDisplayCSUI2 Assembly Version: 1.0.0.0 Win32 Version: 03.18.02.50 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/DgnDisplayCSUI2.DLL ---------------------------------------- Anonymously Hosted DynamicMethods Assembly Assembly Version: 0.0.0.0 Win32 Version: 4.8.4220.0 built by: NET48REL1LAST_C CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll ---------------------------------------- PresentationFramework-SystemData Assembly Version: 4.0.0.0 Win32 Version: 4.8.4220.0 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll ---------------------------------------- System.Numerics Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll ---------------------------------------- Bentley.RSS.Common Assembly Version: 1.0.0.0 Win32 Version: 10.13.00.48 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Assemblies/Bentley.RSS.Common.DLL ---------------------------------------- Ali.MicroStation2020 Assembly Version: 20.10.13.0 Win32 Version: 10.0.14.2 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/mdlapps/ALi.MicroStation2020.DLL ---------------------------------------- System.Net.Http Assembly Version: 4.0.0.0 Win32 Version: 4.8.3761.0 built by: NET48REL1 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Net.Http/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Net.Http.dll ---------------------------------------- Microsoft.ApplicationBlocks.ExceptionManagement.Interfaces.1.0 Assembly Version: 1.0.0.0 Win32 Version: 01.00.00.02 CodeBase: file:///C:/Program%20Files/Bentley/MicroStation%20CONNECT%20Edition/MicroStation/Microsoft.ApplicationBlocks.ExceptionManagement.Interfaces.1.0.DLL ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Jon Summers said:Customer moved to a PC having MicroStation CONNECT Update 13 with a similar result.
It sounds like the problem is in the application itself.
Because I assume it's not possible to debug the application using the customer's PC, can the application be modified to catch ReflectionTypeLoadException and to report / store LoaderExceptions property as recommended in the exception output?
Does addin reference only MicroStation assemblies or it depends also on others?
How application is configured? Does it target NET Framework 4.6.2 or a different version?
Jan Ĺ legr said:How application is configured? Does it target NET Framework 4.6.2
This is an AddIn developed on Update 14 using framework 4.6.2.
When did CONNECT move from 4.6.1 to 4.6.2?
Jon Summers said:When did CONNECT move from 4.6.1 to 4.6.2?
I am not sure, but NET 4.6.2 is used for last several versions. I am pretty sure at least CE Update 10 was based on 4.6.2 already.
Jan Ĺ legr said:Can the application be modified to catch ReflectionTypeLoadException?
But how can I write a try {} block around the AddIn's Run method? Don't I need to see inside MicroStation and trap LoadMdlProgram (which of course I can't do)?
try {}
Run
LoadMdlProgram
Jon Summers said:Don't I need to see inside MicroStation and trap LoadMdlProgram (which of course I can't do)?
No, you don't need try / catch in this case.
Unhandled exceptions flow up to a domain level, where they can be processed using domain exception handler (see e.g. this page). I have not any code snippet, tested in MicroStation, but in general there is no reason why catching exceptions at domain level should not work in the same way as in normal standalone NET application.
Hi Jon Summers,
Unfortunately the .NET Exception Dialog text does not often provide enough detail/precision to fully resolve the underlying issue/conditions though provides some general insights related to the problem.
Each exception/crash dump is like a fingerprint (each problem unique and often different) and best to Collect Exception Data using a client tool like DebugDiag to capture (ok) small memory (but w/o heaps) or (better) full memory (w/heaps, handles, .NET troubleshooting, etc.) dump files that can be used to help resolve issues with greater precision. See also: Debug Microsoft Apps.
However the general message Jan points out along with significant software version differences and probably equally important; a "deployed" customization; I suggest taking a look at your application References and/or Installer and confirm proper your custom .NET assemblies are being deployed as needed.
For either deployment condition that you need to know (or enforce) ahead of time make sure the Project Reference property of CopyLocal is set accordingly; CopyLocal=false for GAC registration, or CopyLocal=true for DLL/Assembly path discovery.
HTH,Bob
