[CONNECT] Check if Design History is enabled in VBA?
Hi all,
Does anyone know of a method in VBA to detect if the active design file has Design History enabled or not?
The mdl wrapper method i found in old posts crashes in CE and the Property Handler method always results in a negative result.
Mark
