I am trying to get some information about the active printer. This routine give me the Print Driver Name, the paper name, and the orientation. What I am really missing is the Windows Printer Name.
How do I get the Windows Printer Name? (IE. I can get a result of "Printer.pltcfg", but I also need to get the "HPOfficeJetPro" name from the active Windows printer.)
Sub ActivePrinterSettings() Dim Result As String CadInputQueue.SendCommand "DIALOG PLOT " Result = GetCExpressionValue("plotUI.uiPrinterName") Result = Result & vbNewLine & GetCExpressionValue("plotUI.uiPaperName") Result = Result & vbNewLine & IIf(GetCExpressionValue("plotUI.uiOrientation") = 0, "Portrait", "Landscape") Result = Result & vbNewLine & GetCExpressionValue("plotUI.uiFormSizeX") & ", " & GetCExpressionValue("plotUI.uiFormSizeY") MsgBox Result End Sub
--Thanks,--Robert Arnold
RobertArnold said:I am trying to get some information about the active printer
MicroStation CONNECT Update 13 introduced the PrintManager object. There are a few other classes related to printing.
PrintManager
We wrote a Printer Enumerator for VBA a year or two ago.
Hi Jon,I had seen a couple of your printer related pages. I do appreciate your website and notes. Right now I'm trying to find the active Microstation-Windows printer, rather than a list of printers. Also, I see the PrintManager--which has events, but does not give a lot of info about the active settings. Please let me know if I'm missing something.
I'm hoping that this should be a simple GetCExpressionValue command. I wish that I knew all the different plotui parameters.
--Thanks,--Robert
Hi Robert,
see the sample below. This used to work flawlesly in V8i, but it needs to be fixed for CONNECT.
Private Declare Function mdlDialog_find Lib "stdmdlbltin.dll" _ (ByVal DialogID As Long, _ ByVal ownerMD As Long) As Long Private Declare Function mdlWindow_titleGet Lib "stdmdlbltin.dll" _ (ByVal titleP As String, _ ByVal titleChars As Long, _ ByVal windowP As Long) As Long Private Declare Function mdlSystem_findMdlDesc Lib "stdmdlbltin.dll" _ (ByVal nameP As String) As Long ' Returns a pointer to a structure ' Get printer name from window title Public Function GetPrinterName() As String Dim status As Long Dim lngPw As Long lngPw = 0 Const strTaskID As String = "PLOTDLG" Const lngDialogID As Long = 1200& status = mdlSystem_findMdlDesc(strTaskID) If status <> 0 Then lngPw = mdlDialog_find(lngDialogID, status) End If 'if plot dialog is not open If lngPw = 0 Then Exit Function Dim strTitle As String strTitle = Space$(255) mdlWindow_titleGet strTitle, 255, lngPw strTitle = Utils.TruncateAtEOS(strTitle) Dim name As String name = strTitle name = Left(name, InStrRev(name, "(") - 1) name = Mid(name, InStr(1, name, "-") + 1) GetPrinterName = Trim(name) End Function
And these are other published expressions (again in V8i) that I know of:
Tom
Per Artur Goldsweer, There is another CExpression: "plotUI.uiSysPrinterName" which returns the name of the selected printer. E.g. if the expression "plotUI.uiPrinterName" returns "Windows printer", the expression "plotUI.uiSysPrinterName" returns the exact name of the selected Windows printer name.
That means that my expanded test looks like:
Sub ActivePrinterSettings() Dim Result As String CadInputQueue.SendCommand "DIALOG PLOT " Result = GetCExpressionValue("plotUI.uiPrinterName") Result = Result & vbNewLine & GetCExpressionValue("plotUI.uiSysPrinterName") Result = Result & vbNewLine & GetCExpressionValue("plotUI.uiPaperName") Result = Result & vbNewLine & IIf(GetCExpressionValue("plotUI.uiOrientation") = 0, "Portrait", "Landscape") Result = Result & vbNewLine & GetCExpressionValue("plotUI.uiFormSizeX") & ", " & GetCExpressionValue("plotUI.uiFormSizeY") MsgBox Result End Sub
Thanks again for all the suggestions.
Answer Verified By: RobertArnold
