MicroStationAPI tool class DgnElementSetTool provides method _DoLocate...
DgnElementSetTool
_DoLocate
HitPathCP _DoLocate (DgnButtonEventCR ev, bool newSearch, ComponentMode complexComponent)
The last argument complexComponent is unclear. It's documented like this...
complexComponent
Those parenthesised values puzzle me. Note that there's no documentation for value None.
None
Here's the definition of that enum in \DgnPlatform\Locate.h...
enum class ComponentMode { None = 0, //! Set cursor index to head of path (0). Innermost = 1, //! Set cursor index to last entry in path (-1). NormalChild = 3, //! Set cursor index to innermost public component of a complex element (same as None if no normal cells in path)... SharedChild = 4, //! Set cursor index to innermost public shared component (same as NormalChild if no shared cells in path)... };
Innermost
NormalChild
Here's the code that ends up being called to set the path index...
void ElementLocateManager::SetPathIndex (HitPathP hit, ComponentMode complexComponent) { if (NULL == hit) return;
int index = 0;
switch (complexComponent) { case ComponentMode::None: // outermost complex header { index = 0; break; }
case ComponentMode::Innermost: // last element in path { index = -1; break; }
case ComponentMode::InnermostHeader: // innermost complex header { ElementRefP elem;
for (int i=0; elem = hit->GetPathElem (i); i++) { if (NULL == elem) break;
if (elem->IsComplexHeader ()) index = i; } break; }
case ComponentMode::NormalChild: // innermost public component { index = hit->GetPathIndex (hit->GetChildElem ()); break; }
case ComponentMode::SharedChild: // innermost public component (allow components of shared cell definitions) { index = hit->GetPathIndex (hit->GetSharedChildElem ()); break; } }
hit->SetCursorIndex (index); hit->SetComponentMode (ComponentMode::Innermost == complexComponent); // Set component mode for flashing of extended elements... }
ElementRefP DisplayPath::GetChildElem (ExposeChildrenReason reason) const { if (m_path.empty ()) return NULL;
ElementRefP innerRef = NULL;
for (DgnElemRefArray::const_iterator curr = m_path.begin (); curr != m_path.end (); ++curr) { ElementHandle eh (innerRef = (ElementRefP) *curr);
// Quit at the first element that doesn't expose components... if (!eh.IsValid () || !eh.GetHandler ().ExposeChildren (eh, reason)) break; }
return innerRef; }
ElementRefP DisplayPath::GetSharedChildElem (ExposeChildrenReason reason) const { if (m_path.empty ()) return NULL;
if (!eh.IsValid ()) break;
if (eh.GetHandler ().ExposeChildren (eh, reason)) continue;
ISharedCellQuery* scQuery;
// Quit at the first element that doesn't expose components that isn't a shared cell instance... if (NULL == (scQuery = dynamic_cast <ISharedCellQuery*> (&eh.GetHandler ())) || !scQuery->IsSharedCell (eh)) break; }
Answer Verified By: Jon Summers
