I wanted to figure out how to create a TextTable using the MicroStationAPI. With that completed, I then went on to use a TextTable seed as a template for a TextTable.
TextTable
That solution is described here, where you will find a link to a C++ TextTableHelper class.
TextTableHelper
Hi Jon,Unfortunately the link you provided has gone down.If you still have the solution as described in the old link, are you able to amend your post with it?Regards,Remy
Remy Moerland said:Unfortunately the link you provided has gone down
The LA Solutions web site is no longer public.
