Re the blog above at https://communities.bentley.com/products/programming/microstation_programming/b/weblog/posts/import-points-ce-mvba-released-to-microstation-users is this like Import coordinates and what is a Point file?
The announcement of that freeware, and two other VBA utilities, is in the MicroStation Forum.
Why not post your question in that Forum as a response to that announcement? You could also read the blog about Import Points CE, which makes it clear what the author means by a point file.
