Hi.
I am getting the body from element descriptor as follows:
int iStatus = mdlKISolid_elementToBody(kBody, pElemDescr, m_pDgnModelRef);
Later, using mdlKISolid_bodyToElements() API as follows to get the elements from body. But this API neither crashing or returning a fail error code. Instead it is returning success but there is no elements.
try { iStatus = BSIERROR; int iStatusLocal = mdlKISolid_bodyToElements(pElemDescr, kBody, FALSE, -1, NULL, m_pDgnModelRef); mdlKISolid_free(kBody); if (BSISUCCESS == iStatusLocal) iStatus = BSISUCCESS; } catch (...) { iStatus = GOTEXCEPTION; }
Any other way to get the elements? Any better suggestion.
Thanks in advance.
Sampath.
Hi Bency,
please read and follow this forum best practices! Without knowing product and a version (build number) you use, it's hard to answer you question.
Also, please user Insert > Insert code tool every time you post a code snippet. To read code formatted as a plain text is confusing (plus the tool is able to colorize C++ and C# code nicely).
Bency Gregorioz said:Any other way to get the geometry?
What is your intention? What exactly do you need? Pure geometry (faces, vertices, edges)? And what type of element do you expect?
Bency Gregorioz said:Any better suggestion.
The simplest way I know is to use IElementGraphicsProcessor, but without knowing what version do you use and also what element type(s) you want to process (solid, SmartSolid, parametric solid...), it's hard to guess more.
With regards,
Jan
Thanks jan for quick response.
I need smart solid. If i use mdlKISolid_satDataFromElement() this API, all the Smart Surfaces in the dgn file are getting properly. But this is an undocumented API and there are lots of crash for other dgn files and even the Bentley help suggested not to use this API.I am working on Microstation V8i (08.11.09.357) and SDK MicroStation V8i SDK 08.11.09.292.
Bency Gregorioz said:I need smart solid.
I guess not, because you wrote that you call the function to get the geometry. SmartSolid is an "MicroStation element", stored in DGN as a cell with extra information attached. It's the reason why I ask what exactly from geometry do you need.
Bency Gregorioz said:I am working on Microstation V8i (08.11.09.357) and SDK MicroStation V8i SDK 08.11.09.292.
Why do you use different SDK than MicroStation? For MicroStation 08.11.09.357 (which is very old version btw), the same SDK build .357 was released. Probably not big issue in this case, but it's a general recommendation to always use the same SDK as MicroStation.
My previous answer is still valid: See IElementGraphicsProcessor, which is part of new C++ MicroStationAPI, available I guess from V8i SS3 (?). I have no experience with this mechanism in V8i, but it's widely used in CE (and in some scenarios it's the only way). It allows to decompose any MicroStation graphic element into components, depending on class configuration.
How is pElemDescr declared? You've passed a variable called pElemDescr into both mdlKISolid_elementToBody and mdlKISolid_bodyToElements, but one takes an MSElementDescr* for an existing element and the other takes an MSElementDescr** to allocate and return a new element. So if pElemDescr is declared as MSElementDecr* pElemDescr = nullptr; you'd do this: mdlKISolid_bodyToElements(&pElemDescr, ...).
-B
* kBody passed to mdlKISolid_elementToBody looks suspicious as well...if this is a KIBODY** then it can't be passed to mdlKISolid_bodyToElements/mdlKISolid_free that require a KIBODY*...
MSElementDescr* pElemDescr = NULL; ProcessElementByBodies(&pElemDescr); //Defination void ProcessElementByBodies(MSElementDescr** pElemDescr) { int iStatus = BSIERROR; KIBODY* kBody = NULL; iStatus = getBody(m_pElemDescr, &kBody); if (iStatus == BSISUCCESS && NULL != kBody) { try { iStatus = BSIERROR; int iStatusLocal = mdlKISolid_bodyToElements(pElemDescr, kBody, FALSE, -1, &m_pElemDescr->el, m_pDgnModelRef); mdlKISolid_free(kBody); if (BSISUCCESS == iStatusLocal) iStatus = BSISUCCESS; } catch (...) { iStatus = GOTEXCEPTION; } } }
MSElementDescr** pElemDescr = NULL; // <- Incorrect
MSElementDescr* pElemDescr = NULL; // <- Correct
Look at your usage of kBody as well as it appears you haven't done much with C++ pointers...
Sorry. Its a typo.
MSElementDescr* pElemDescr = NULL; This is what there in my code.
This is the getBody() implementation :
int getBody(MSElementDescr* pElemDescr,KIBODY** kBody) { int iStatus = BSIERROR; try { iStatus = mdlKISolid_elementToBody(kBody, pElemDescr, m_pDgnModelRef); } catch (...) { iStatus = GOTEXCEPTION; } return iStatus; }
I hope you understood, how i use the kBody now.
BTW, i am not facing any syntactical errors or crashes with my code. Issue is with the Microstation API itself. mdlKISolid_bodyToElements() is getting success but there are no elements in it.
Instead of using that API, if i use mdlKISolid_satDataFromElement(), i am able to get the sat data and graphics properly. But as i said earlier, this is an undocumented API and giving crashes to other dgn files and not encouraging to use it.
Jan Ĺ legr said:I have no experience with this mechanism [IElementGraphicsProcessor] in V8i
It works well.
Bency Gregorioz said:using mdlKISolid_bodyToElements() API as follows to get the elements from body
Prefer Jan's recommendation to use IElementGraphicsProcessor.
Why?
I wrote a simplest test code snippet without any error check. It works well for my attached test.dgn. FYI.
void kiSolidTest() { MSElementDescrP inEdP=NULL, outEdP=NULL; KIBODY* kBody=NULL; mdlAssoc_getElementDescr (&inEdP, NULL, 16904L, ACTIVEMODEL, FALSE); mdlKISolid_elementToBody(&kBody, inEdP, ACTIVEMODEL); mdlKISolid_bodyToElement(&outEdP, kBody, FALSE, -1, NULL, ACTIVEMODEL); mdlElmdscr_add (outEdP); mdlElmdscr_freeAll (&outEdP); mdlElmdscr_freeAll (&inEdP); mdlKISolid_freeBody(&kBody); }
8712.test.dgn
Hi Yong.
Its almost similar code what i have written, but the smart surfaces are not converting to elements.
Sampath
