The attached MVBA has a UserForm with a ComboBox that is enabled by a CheckBox. The "run time error" occurs when the string array is a applied to the combobox. The second part of the module is used to correlate(make equal) the return index value to the linestyle in the active design file.
1781.ComboBox_ListArray.mvba
I followed the maxim 'Simplicate and Add Lightness'.
5428.ComboBox_ListArray.mvba
This version works, as far as I can tell.
Answer Verified By: Robert Hook
Steven W.
CAD Manager
MPS Engineering Inc
813-855-2721
Steven W said:William Bushnell StoutSteven W.
You have two names, or are you really two people?
