When I create a Display Rule manually it works...
When I write the same rule using code...
DisplayRulePtr displayRule = mgr.MakeRule (L"ELEMENT.Area Feature.occupied=No");
The Display Rules dialog tells me Unrecognized criteria! There is no further explanation. How can I diagnose problems with Display Rules?
You can reproduce this using the delivered SDK example ..\View\DisplayRule. If I use that example's command to add a rule, it also fails when the rule involves an Item Type; the code succeeds if it concerns a raw element property.
..\View\DisplayRule
The failure seems to occur when setting a rule for an Item Type property value. Is there something about Item Types that affects the way in which a rule should be specified?
Does "element.ItemTypeLibraryName::ItemTypeName::PropertyName=Value" work?
Yongan.Fu said:Does "element.ItemTypeLibraryName::ItemTypeName::PropertyName=Value" work?
Thanks for the suggestion. Unfortunately not...
I've tried just about every combination of library/item type/property and name/internal name with no success.
If I write a similar expression involving an Item Type property, manually, it works. It's attempting the same through the API that fails. You can use the SDK example ..\SDK\examples\View\DisplayRule to test this problem.
We need to know the recipe for the secret sauce!
Hi Jon,
is it possible to share test case (DGN with Item Type Lib, even limited to queried property, and one element)?
Jan
Jan Ĺ legr said:is it possible to share test case (DGN with Item Type Lib, even limited to queried property, and one element)?
Here's a DGN file with AreaAnnotator and DoorKeeper Item Type defintions, and several DGN elements tagged with those Item Types.
AreaAnnotator8.dgn
Wrote a listRuleCondition function to check your DGN file and got the below results:
But when I checked your DisplayRule definition, its definition seems incorrect. Shown as below:
[What we see the rule condition in the Display Rules dialog is just rule description not its definition. We can see its definition in Condition Editor dialog].
Then I correct it as below:
and re-get its content as below:
So the format "element.ItemTypeLibraryName::ItemTypeName::PropertyName=Value" is almost right except:
Yongan.Fu said: the format "element.ItemTypeLibraryName::ItemTypeName::PropertyName=Value" is almost right
Thanks! How do you show the complete expression in the Message Center?
When I set the rule programmatically, it remains incorrect whether I use the display name or the internal name of the schema...
We can get those by calling GetInternalName()...
GetInternalName()
Bentley::WString ItemTypes::GetInternalName (WStringCR name) { WString internalName; ECNameValidation::EncodeToValidName (internalName, name); return internalName; }
Some EC classes have a similar method already available.
Jon Summers said:How do you show the complete expression in the Message Center?
This isn't MessageCenter, just a temporary message dialog. I use below function listDisplayRules to do this.
void listDisplayRules(WCharCP ruleSetName) { DgnFileP pDgnFile = ISessionMgr::GetActiveDgnFile(); DisplayRuleSetCP ruleSetCP = DisplayRulesManager::GetDisplayRuleSetByName(ruleSetName, *pDgnFile); if (nullptr == ruleSetCP) { mdlDialog_dmsgsPrint(L"nullptr == ruleSetCP"); return; } DisplayRuleSetPtr ruleSet = ruleSetCP->Clone(*pDgnFile); for (DisplayRulePtr rule : ruleSet->GetDisplayRules()) { WStringCR ruleCond = rule->GetCondition(); mdlDialog_dmsgsPrint(ruleCond.GetWCharCP()); } }
Jon Summers said:When I set the rule programmatically, it remains incorrect whether I use the display name or the internal name of the schema...
I firstly create a test rule set named FooRuleSet. Then I type below keyins which works fine.
MDL LOAD DisplayRule displayrule create rule FooRuleSet element.DgnCustomItemTypes_AreaAnnotator_1_0::Area__x0020__Feature::occupied=True ElementDisplay
Jon Summers said:We can get those by calling GetInternalName()...
Yes. You are right. But without correcting DisplayRule example, we have to keyin raw rule condition.
Yongan.Fu said:without correcting DisplayRule example,
Here's a modified DisplayRule example.
DisplayRule.zip
I've added a new command:
displayrule create ruleItemType rule-set-name schema-name item-name property-name condition ElementDisplay
Example:
displayrule create ruleItemType FooRuleSet AreaAnnotator_1_0 "Area Feature" Occupied =True ElementDisplay
That rule does nothing very exciting! It assembles those arguments into a string and then creates the rule. However, it doesn't work. The best I can do is to create a schema name that looks correct to the human eye, but results in an invalid rule definition.
I conclude that the DisplayRule class is looking for a schema name in a very particular format, but which is undocumented.
I continue to search for a solution to this problem: unable to set a Display Rule for an Item Type programmatically. The modified DisplayRule example includes a new command to help analyze the problem.
Have you followed my test steps strictly? It really can create our own rule.
Maybe need us close and reopen the Display Rule dialog to check the result.
