My goal is to work with only the visible lines and line strings within a cell. I figured out how to access the lines and linestrings, but I don't know how to detect if the element is visible in the current view or not. Is there a way to test for this? I guess another way ask is if the level is on or off in the current view. Here is my little test program.
Private Sub test(XCell As CellElement) Dim enumer As ElementEnumerator Set enumer = XCell.GetSubElements Dim q As Long q = 0 Do While enumer.MoveNext If (enumer.Current.Type = msdElementTypeLine Or enumer.Current.Type = msdElementTypeLineString) Then 'maybe I'd like to test here to see if it is visible. q = q + 1 End If Loop MsgBox FormatNumber(q, 0) End Sub
Minion
minion said:I don't know how to detect if the element is visible
See VBA Help topic Hiding an Element.
