All,
We have a legacy MicroStation application which has been problem-free but which was recently tested running on MicroStation 10.15.00.74. The application runs as an INITAPP and never calls mdlSystem_enterGraphics. Upon calling mdlSystem_newDesignFile, the following error is displayed in the Text Window:
log4net:ERROR XmlHierarchyConfigurator: Cannot find Property [createpath] to set object on [log4net.Appender.RollingFileAppender]
Any idea what could cause this behavior and/or possible workarounds?
TIA
Steve
Jon Summers said:Who has time to read through millions of lines of logging?
There is typically no reason, why anybody should read complete logs with millions of lines ... probably it would be a proof of bad application or operation design.
Log4xxx (which has been part of my probably all applications for last few years ;-) can be easily configured to store logs in database(s). It allows to monitor logs automatically and to analyze selected data only. And the result of such analysis is, when needed, reviewed by a human.
It's not typical for desktop applications, but I remember presentation on some conference about monitoring server streaming system. IT director explained how they log about 5000 parameters in parallel, ever second, to be able to track (and try to predict using AI) unexpected issues ;-)
Jan
Hi Robert,
We are still getting this error in Update 16. Can you please confirm if Bentley has fixed the issue?
It is becoming a perennial issue ;)
I see it in Update 17.2.
Cheers,
/Chris Z.
