There is a straightforward way to manually attach item types to references as described here:
How to attach Item Type to a Reference file - MicroStation Wiki - MicroStation - Bentley Communities
I attach these item types via the api but that is (probably) not relevant.
When I assign new values to the items (manually or via api) and then move and/or rotate the refrences the values of the items are strangely reset to the initial values (not neccessarily the default values). At other times (and I am not able to reproduce this) the values remain unaltered (as they should).
In other words: Most of the time I move a reference changes to the values are lost and sometimes not. On the surface this behaviour seems to be completley random.
Do you have any idea what is going on?
Max K said:I attach these item types via the api but that is (probably) not relevant
Asumptions are bad, especially for programmers!
