migrating an old V8i MDL application I'm missing the functions AllowActivation(), Activate() and ReleaseWriteLock() formerly defined in referenceFile.h:
/*--------------------------------------------------------------------------------------+ | | | $Copyright: (c) 2008 Bentley Systems, Incorporated. All rights reserved. $ | | +--------------------------------------------------------------------------------------*/ #pragma once #ifdef __cplusplus #include <refernce.h> #include <msdgnmodelref.fdf> #include <msdgncache.fdf> #include <viewcontext.h> #include <vector> typedef std::vector <struct GPArray*> RefClipCurves; #ifdef REFERENCE_FILE_CLASS /*=================================================================================**//** * A ReferenceFile is an object that is the in-memory representation of a "reference file" attachment of one model to another. Any model * may have multiple ReferenceFiles attached to it, and conversely any model may be referenced through many ReferenceFiles. * Note that when a model is referenced multiple times and also has ReferenceFiles of its own (aka "nested reference"), there * will be a unique ReferenceFile object for each path to the child reference through each parent. * @bsiclass Bentley Systems +===============+===============+===============+===============+===============+======*/ struct referenceFile : _referenceFile { private: virtual void MakeClassAbstract() = 0; public: //! Get the DgnModelRef for this ReferenceFile, or NULL MSCORE_EXPORT DgnModelRefP GetModelRef() const {return file_id.modelRef;} //! Get the DgnCache of the model this ReferenceFile displays, or NULL. DgnCacheP GetDgnCache() const {return mdlModelRef_getCache(file_id.modelRef);} //! Get the DgnFile holding the model this ReferenceFile displays, or NULL. MSDgnFileP GetDgnFile() const {return (MSDgnFileP) dgnCache_getDgnFile(GetDgnCache());} //! If this is a nested ReferenceFile, return its parent ReferenceFile. Otherwise, returns NULL. MSCORE_EXPORT ReferenceFileP GetParent() const; //! If this is a nested ReferenceFile, get the parent's DgnModelRef. Otherwise, returns NULL. MSCORE_EXPORT DgnModelRefP GetParentModelRef() const; //! Check whether this ReferenceFile can be activated. There are various reasons why some ReferenceFiles cannot be activated. //! For example, ReferenceFiles that have been geographically reprojected cannot be edited. Also self-references cannot be displayed. //! Also, applications can mark their ReferenceFiles as non-editable themselves. MSCORE_EXPORT bool AllowActivation() const; //! Activate (make editable) this ReferenceFile. If the DgnFile holding this ReferenceFile is not currently opened for write access, //! this method will attempt to reopen the file for write access. If that succeeds, all of the DgnCaches of that file are emptied and //! then reloaded. The DgnModelRef of this ReferenceFile becomes the ActiveModel. //! @return SUCCESS if this ReferenceFile was successfully prompted to become the ActiveModel, and ERROR if the attempt failed. //! @note It is important to recognize that because the file may have been edited by another user before the ReferenceFile is activated, //! the contents of the DgnCache are potentially significantly different than what the user was observing when (s)he requested the //! activation. //! @note After this call, the current command is terminated and the default command is started. This happens whether the activation //! process succeeds or not. //! @see ISessionMgr::MakeActiveModel MSCORE_EXPORT StatusInt Activate(); //! Release the write lock for the DgnFile associated with this ReferenceFile. //! @param[in] releaseChildLocksToo If true, find all nested ReferenceFiles of this ReferenceFile and attempt to release their //! write locks too. //! @see ISessionMgr::ReleaseWriteLock MSCORE_EXPORT StatusInt ReleaseWriteLock (bool releaseChildLocksToo=false); }; #endif #endif // __cplusplus
I can't find new versions of these functions e.g. in DgnAttachment.h
Any ideas?
Regards, Tom
It seems this is not currently available from published api, DgnAttachment would be the correct place for these. Log a request with support?
Hi Brien, thank you for your answer; I logged a service request.
