When we do something like this (taken from SDK ..\Visualization\DisplayStyleExample)...
ViewGroupCollectionCR viewGroups = dgnFile->GetViewGroups(); ViewGroupPtr viewGroup = viewGroups.GetActiveP(); if (!viewGroup.IsValid()) return; int viewIndex = 0; ViewInfoR viewInfo = viewGroup->GetViewInfoR (viewIndex);
ViewGroup
ViewInfo
> Is the active ViewGroup always available when MicroStation has a DGN file open?
It should be, the active view group is made active when a file is opened...but you should always check that you have a valid ptr...
> Do all eight ViewInfo instances exist even when some views are closed?
Closed or open, there will always be a ViewInfo for views 0-7, that's why it can return a reference instead of a pointer (the on/off state is a ViewFlag).
That said, it's possible for a ViewGroup to not define all 8 views (usually see this w/DWG files), information about whether a view is defined comes from the ViewPortInfo.
-B
Answer Verified By: Jon Summers
