i need to reduce the above tag size. Is there any way to change the size by using vba? pls let me know
Dharma SA said:i need to reduce the above tag size
Your screenshot tells us nothing! I can see a row of eight zeros. We can't tell their size. You haven't told us what an acceptable size would be.
Dharma SA said:Is there any way to change the size by using vba?
What's special about VBA? VBA automates what you can do as a user — it doesn't perform magic. Can you adjust the 'size' of that tag value using MicroStation tools? What tools let you adjust the size to your liking?
