What is the suggested way for logging an MDL app that is loaded with no MicroStation UI through MS_INITAPPS? I tried the basic Console.WriteLine but nothing ever gets printed on the Windows cmd window. I have some System.Console.WriteLine( ) within the MDL Run method but it never gets printed as I would expect. Below sample code.
[Bentley.MstnPlatformNET.AddIn(ApplicationType = MdlApplicationType.InitApp, MdlTaskID = "SampleClass")] internal sealed class SampleClass : Bentley.MstnPlatformNET.AddIn { private static SampleClass Addin; private Bentley.Interop.MicroStationDGN.Application app; private SampleClass(System.IntPtr mdlDesc) : base(mdlDesc) { // save a reference to addin to prevent it from being garbage collected. Addin = this; } protected override int Run(string[] commandLine) { System.Console.WriteLine("In Run"); app.Visible = false; DesignFile dgn = app.OpenDesignFile("C:\\sample.dgn", true, MsdV7Action.Workmode); System.Console.WriteLine("after open"); switch (this.ApplicationType) { case MdlApplicationType.User: System.Console.WriteLine("User"); break; case MdlApplicationType.DesignApp: System.Console.WriteLine("DesignApp"); break; case MdlApplicationType.InitApp: System.Console.WriteLine("Initapp"); break; } return 0; } }
Here is the Windows cmd I am running:
microstation.exe ustation -WAsampleclass -Debug
And as well, yes, the MDL app is in the Mdlapps folder in MicroStation.
Extract from msdebug.txt, you can see the SampleClass MDL being loaded:
.... Processing macro file [C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\config\appl\pw.cfg] Starting skip to endif, [C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\config\appl\pw.cfg], line 16, depth = 0. if, [C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\config\appl\pw.cfg], line 17, depth = 1. endif, [C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\config\appl\pw.cfg], line 19, depth = 1. endif, [C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\config\appl\pw.cfg], line 23, depth = 0. (Application): PWDIR=HKEY_CURRENT_USER\SOFTWARE\Bentley\ProjectWise\Path [HKEY_CURRENT_USER\SOFTWARE\Bentley\ProjectWise\Path] (Application): PWDIR=C:\Program Files\Bentley\ProjectWise\ [C:\Program Files\Bentley\ProjectWise\] Processing macro file [C:\Program Files\Bentley\ProjectWise\bin\mcm.cfg] Starting skip to endif, [C:\Program Files\Bentley\ProjectWise\bin\mcm.cfg], line 20, depth = 0. if, [C:\Program Files\Bentley\ProjectWise\bin\mcm.cfg], line 23, depth = 1. endif, [C:\Program Files\Bentley\ProjectWise\bin\mcm.cfg], line 27, depth = 1. endif, [C:\Program Files\Bentley\ProjectWise\bin\mcm.cfg], line 28, depth = 0. (Application): _MCM_CFG_=1 [1] (Application): MS_INITAPPS=SampleClass [SampleClass] (Application): MS_INITAPPS=SampleClass [SampleClass] Starting skip to endif, [C:\Program Files\Bentley\ProjectWise\bin\mcm.cfg], line 48, depth = 0. endif, [C:\Program Files\Bentley\ProjectWise\bin\mcm.cfg], line 50, depth = 0. Starting skip to endif, [C:\Program Files\Bentley\ProjectWise\bin\mcm.cfg], line 51, depth = 0. endif, [C:\Program Files\Bentley\ProjectWise\bin\mcm.cfg], line 53, depth = 0. Starting skip to endif, [C:\Program Files\Bentley\ProjectWise\bin\mcm.cfg], line 54, depth = 0. endif, [C:\Program Files\Bentley\ProjectWise\bin\mcm.cfg], line 56, depth = 0. (Application): PW_MDLAPPS_SUBDIR=v1000 [v1000] ...... ...... MS_IMPORTEDIMAGES : System = C:\ProgramData\Bentley\connectsharedcontent\materials\imported\ MS_INCLUDEPARAMETRICDEFMODELS: System = TRUE MS_INITAPPS : System = SampleClass <Locked> MS_INPUT_CONFIGXML : System = C:\Users\<user>\AppData\Local\Bentley\MicroStation\10.0.0\prefs\Personal.inputConfiguration.xml MS_INPUT_CONFIGXMLSEED: System = C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\data\inputConfiguration.xml ...... ......
Hi Mervin,
Mervin Bowman said:What is the suggested way for logging an MDL app
I think there is no recommended or preferred logging solution.
In C#, you have plenty of options, so you can easily choose solution, that fits the best specific needs.
MicroStation itself uses log4net libraries, so in MicroStation installation, you can find e.g. Bentley.logging.log4net-2.0.dll assembly, which seems to contain standard log4net API.
In the past (in V8i time), I added log4net to my projects using NuGet package, but maybe in CE, it makes sense to use what is built-in.
With regards,
Jan
Answer Verified By: Mervin Bowman
