We have our own encrypt mechanism . We would like to implement it when save action triggers.
Also we would like to decrypt it when open action triggers.
We tried with Read and Write API hooking. But its not Succeeded.
Is there any possible way to do it?
Thanks in Advance.
Hi Rajesh,
I am not sure whether it's possible. On the other hand, I am quite sure that to use save event trigger is wrong idea and will not work, because it does not allow to inject (modify) the saving process.
What you can try is to use DocumentManager, because - accordingly to documentation - it virtualizes access to physical files so that a host program and its applications can be written to work equally well with the native file system or a document management system (DMS). But I am not aware of any example how to do it.
With regards,
Jan
Rajesh Varatharajan said:We have our own encrypt mechanism
Why, when MicroStation has its own security mechanism?
