Hello everyone,
I know this is kind of a trick question. But it would be nice to have a trick or solution.
I have a variable in the makefile defined like “myvar=was:immer:gefaellt” I like to have it as a file name like: “$(tmp)/$(myvar).txt”
This will of course not work, ‘:’ is illegal in a file name. In a batch file I could do it this way to replace ‘:’ with ‘_’:
SET MYVAR=was:immer:gefaellt SET MYNAME=%TMP%\%MYVAR::=_%.TXT :: => “C:\Users\SomeOne\AppData\Local\Temp\was_immer_gefaellt.TXT”
How could I do this trick in a bmake-file? I tried to call “@SET…” from the makefile. But I did not get the result back, because this would start some new child process.
Thanks a lot!
Volker Hüfner said:How could I do this trick in a bmake-file?
Whenever I've posted a tricky question about bmake here, I seldom receive a response. I find that it's more fruitful to search other sources of make file information. For example...
Hi Volker,
try this :-)
MYVAR = was:immer:gefaellt always: |[== MYVAR1: $(MYVAR) ==] ~set MYVAR $(TMP)\\$[@subst :, \\, $(MYVAR)] |[== MYVAR2: $(MYVAR) ==]
Jan
Answer Verified By: Volker Hüfner
