Not Rule or Dependency
Hi Everyone,
I am new to mdl programming.  I have Microstations v8i select series 4 and I have downloaded the v8i SDK.
I first want to compile and create a simple mc source file to a ma file and then try to execute it as a test.
The program is that when I attempt this we bmake, I am getting an error that I can not determine the cause.
here is the source file:
#include <mdl.h>
#include <dlogitem.h>
int main()
mdlDialog_openInfoBox(“Hello World!!”);
return 0;
I open the MicroStation Developer Shell and type the following:
C:\PROGRA~2\Bentley\MICROS~1\MICROS~1>bmake c:\hastus\hw.mc
Bentley Systems Make Utility. Version 08.11.09.04, Feb 10 2014
Thu Mar 11 10:51:48 2021
c:\hastus\hw.mc(4) : error : not rule or dependency
BMAKE: call trace
    line:    4, c:\hastus\hw.mc
Line 4 in the source is int main().  What is wrong with this line?
Just a note, I have not installed VS 2005.  I'm not sure if I need to for what I am doing.
Could someone help me with what I am doing wrong?
Also not that this is on Windows 10, if that matters.
