[CONNECT C++] MS_INITAPPS and log4net
I've  developed an example InitApp for the CONNECT era, currently Update 15.
I have a working InitApp but it displays a message about log4net.  Here's a screenshot of the message, also showing a trace of the InitApp command-line arguments...
log4net
My guess is that log4net needs be either initialised or prevented from loading.  All ideas welcome!
If anyone wants to see the InitApp CONNECT Edition, its source code is available.
  • Hi ,
    The Log4cxx warning was previously reported (Log4*) and at that time I replied and was informed by development that the cosmetic warning would be removed for MSCE U16 release.  As I am in a cycle performing latest U16 testing and SDK updates and improvements I notice this issue still persists in the latest internal builds.  I am following on this issue to ensure we can do our best to address this in time for the upcoming U16 release.
    I will reply to this thread with an existing or new defect to ensure it can easily be tracked and closed out properly.
    Thank you,
    Bob
    Answer Verified By: Jon Summers
Reply
  • Hi ,
    Thank you,
    Bob
